Will the new cloud wifi also be able to connect to the portal?
Also the iPhone/iPad app does not connect to my cloud wifi..
WiFi cloud attachment to portal
-James-
Re: WiFi cloud attachment to portal
It can, but the portal will require you to use ip/port and thus you need to setup port forwarding on your router.
Ok, once I get the attachment module to work with my RA+, I will try that.
-James-
