RA reboots using cloud wifi
PostPosted: Fri Jan 20, 2017 8:21 pm
The uapp for ios is an older release and it will not connect to the cloud server.
I'm trying to fix a few bugs before I release it a new version.
I know it doesn't reboot when you use the standard ip/port connection. It's something related to the cloud protocol, but I just can't replicate to see where it is.
PostPosted: Fri Jan 20, 2017 8:29 pm
No problem.
Let me know if you want me to do more testing. I love this stuff ( IT guy during the day).
-James-
PostPosted: Sat Jan 21, 2017 5:17 am
current code on my RA+
    ReefAngel.AddStandardMenu();  // Add Standard Menu
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit;
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port7 );
    ReefAngel.Relay.DelayedOn( Port3,2 );
    ReefAngel.StandardHeater( T1_PROBE,Port5,770,780 );
    ReefAngel.PWM.SetDaylight( PWMSlope( 20,10,23,0,50,100,5,0 ) );
    //if (ReefAngel.HighATO.IsActive() ) ReefAngel.Relay.Off( Port1 );
    ReefAngel.Relay.Set(Port1,ReefAngel.LowATO.IsActive() );
    ReefAngel.CloudPortal();
// RA_STRING1=U2FsdGVkX1+k9UBojA2Zl/cGlo+KsPGdeqVYyPkLiZ4ANu8kYtgn0na/dT0wET6s
// RA_STRING2=U2FsdGVkX19G+/qidwTF5uA/QEK9x7ZM12MiXZWqtO8=
// RA_STRING3=Dakota
Why are they two copies of #include <InternalEEPROM.h> ?
-James-
PostPosted: Sat Jan 21, 2017 10:41 am
Probably an oversight I made, but it doesn't hurt any.
I still cannot replicate the problem.
Just for the hell of it, the only thing different is that I don't use the relay box to power the head unit.
Can you try that code with the controller head unit alone powered with the USB power cable and see if it reboots too?
PostPosted: Sat Jan 21, 2017 11:25 am
Yes I can.
Water change time for my tank is tomorrow which will give me the perfect opportunity to test just the head unit.
I will return with the results.
-James-
PostPosted: Sat Jan 21, 2017 12:01 pm
Never mind. I went ahead and tested.
RA+, Cloud Wifi , PH probe, Temp probe and 1 float switch connected. Disconnected relay box and power head unit with USB.
Opened web page to the Uapp and....head unit rebooted.
-James-
PostPosted: Wed Jan 25, 2017 6:32 pm
I have noticed when I use the webwizard and compile code it gives me this message at the end of a succesfull compile:
Dimming Signal
Cloud Wifi Attachment
Wifi Attachment
2014 Main Screen
Standard Menu
Standard Menu
Standard Menu
Standard Menu
===info ||| Sketch uses {0} bytes ({2}%%) of program storage space. Maximum is {1} bytes. ||| [66646 253952 26]
===info ||| Global variables use {0} bytes ({2}%%) of dynamic memory, leaving {3} bytes for local variables. Maximum is {1} bytes. ||| [3282 8192 40 4910]
Progress: 100.00%
Your code was compiled sucessfully.
Is it normal to have both the Cloud Wifi Attachment and the Wifi Attchment in the code? I only pick the Cloud Wifi Attachment from the wizard since that is what I have.
-James-
PostPosted: Thu Jan 26, 2017 2:50 am
Yeah. It is normal.
PostPosted: Thu Jan 26, 2017 9:51 am
Ok, thanks.
Were you able to find anything that would cause the rebooting of the RA yet?
-James-
PostPosted: Thu Jan 26, 2017 10:26 am
Sorry, I didn't have time.
I'm in Germany in fact since last Saturday.
I'll check some more next week when I get back to USA.
PreviousNext
Return to Addons
Users browsing this forum: Bing [Bot] and 2 guests
