RA reboots using cloud wifi
GermanDude
Re: RA reboots using cloud wifi
Post by GermanDude »
How about that. I am from Ludwigshafen am Rhein. That is near Heidelberg.
Drink plenty of German wine. So much cheaper there.
Have fun,
-James-
Ok, I'm back in the USA.
I think I found the problem.
Upload your code again with the web wizard and see if it works now.
Brien H
Post by Brien H »
I too was having this issue (corresponded with you via email). As of your post yesterday, I ran through the wizard again, and am happy to report that I am no longer having a controller reboot when accessing the uapp web app.
Awesome!!
Thanks for reporting back.
GermanDude
Yup, issue fixed here too. No more rebooting.Fantastic Roberto.
The relay page however still has issues for me. The relay status stays on AUTO in the color red.
Hate to be a pain.:-)
-James-
GermanDude
Ok, here is what I noticed with the Uapp.
When I tab between the different taps and go to the relay page, the clock on top of the page stops. It seems to lock the Uapp. I exit and come back in and clock counts again. This is reproducible. All relays say AUTO and are in red. I can however change the relay to turn OFF or ON and both states show the correct color. The clock however has stopped at this point.
Hope this helps.
-James-
Thanks for the troubleshooting.
Let me see what I can find out.
GermanDude
Brien H
Hello fellow reefer.I noticed you are also in Jacksonville.
How is your Cloud Wifi working? Are you having issues with the relay page on the web uapp?
-James-
Go to web based uapp and reload the page. Make sure to reload it with shift pressed or even better clear cache to make sure to get the latest uapp.js file.
Let me know it it shows correctly now.
GermanDude
That`s it. It is working now.
Thank you, Roberto.
-James-
Brien H
Post by Brien H »
GermanDude. Sorry I just saw your post to me regarding Jacksonville. Yes I'm in Jax as well. Nice to meet you....
As far as uapp, after following Roberto's suggestion to shift + reload, I see that my relay page displays the proper colors.
