How do I set it up so it's not possible to switch on and off pumps in the portal?
I just want to have a "monitor mode" where I can see the status of relays and follow ph etc..
Monitor (read only) in portal
Re: Monitor (read only) in portal
Don't use port forwarding and you will get only monitoring.
