Cloud Wifi Attachment
Hey guys,
I just released the cloud wifi attachment in the webstore.
This new wifi attachment has the ability to connect to our new cloud server and provide live feed of your parameters without the need to refresh to grab parameters or relay changes.
Use the web based Uapp to connect to the cloud server.
No more hassle of setting up port forwarding to get control of your Reef Angel Controller.
With the new cloud wifi attachment, you can be always connected to your controller wherever you are.
I have temporarily setup a controller for you to get a taste of what it can do:
1. Go to web based Uapp: http://forum.reefangel.com/uapp
2. Click "Settings" on the bottom bar
3. Click "Add controller" button
4. Enter the following:
IP Address: Leave blank
Port: Leave blank
Username: cloudwifi
Password: 123456
5. Click "Save" button.
6.Click "Relay" on the bottom bar. You should start seeing the relay changing status from red to green and vice-versa. It should update every 5 seconds as I setup to turn on/off every 5 seconds.
7. Click "Status" on the bottom bar. You should start seeing the parameters changing. This one may take a few seconds to update as temperature and humidity don't change that often and there is no pH probe, so it is just floating readings.
Let me know what you think
Port: Leave blank
Username: cloudwifi
Password: 123456
Re: Cloud Wifi Attachment
curious what makes the cloud wifi attachment better than the wifi attachment
The APP will be realtime and not require Refresh-ing
Roberto, did you ever get the app working with this?
Yes, the web based uapp should be fully functional.
Can you try it out and confirm?
Yep, it's working. I tried it on a generic Android 5 tablet, my Samsung 6.0.1 tablet, and my Pixel XL Android 7.1.1. All working fine using Chrome. Awesome!
How about the ability to set memory locations? That's really the only thing missing now.
Sorry, I meant custom memory locations.
Any idea when it will be back in stock Roberto?
I just ordered mine!
is the controller moving away from the desktop app for uploading code and going to the web based app from now on?
I got it in and working. I am running into two issues after switching it out and using the iphone app
1. I changed my labels, below, and now they are not showing up on my reef angel screen and on the uapp when i click download from portal it is pulling the old labels.
2. i changed my settings on the iphone app to the cloud server with correct password and username and it just keeps saying connecting
ReefAngel.CustomLabels[0]="OPEN"; //1
ReefAngel.CustomLabels[1]="Skimmer"; //2
ReefAngel.CustomLabels[2]="FugeLight"; //3
ReefAngel.CustomLabels[3]="Heater"; //4
ReefAngel.CustomLabels[4]="OPEN"; //5
ReefAngel.CustomLabels[5]="OPEN"; //6
ReefAngel.CustomLabels[6]="ATO"; //7
ReefAngel.CustomLabels[7]="OPEN"; //8
RA cannot download labels.
You need to change them in the code.
You can only download labels in the iphone app that you have setup on the portal.
So, the portal and the uapp share the same labels, but the ones in the screen need to be setup on your code.
The problem is that I think I screwed it up.
I changed the custom lables on the new libraries to be pulled from flash instead of using up RAM memory to avoid RAM memory usage, which was causing undesirable results.
When I created the web wizard, which uses the new libraries, I didn't give you the ability to change them
The iphone uapp also needs to be updated to be able to connect to the cloud server. We have not released the update yet.
The only way to get the cloud server connection is to use the web based uapp: http://forum.reefangel.com/uapp
I wanted to make sure the framework was good before I release a new update for iphone.
Thanks for the quick reply. And a big 10/4 on the future app release. That code above is from my sketch loaded with the web-based loader. With that it's not showing up in the display. Do I need to do something different?
Add me to the list of wanting to order one as soon as they are available.
I have my raceway in my garage on an RA without any means to add it to an app or control it, it's more of a monitoring thing due to my all in one xfinity gateway not allowing me to change internal port forwarding channels so I can only control one RA remotely. Was just thinking of bridging my router and buying a new better one just for the RA's but this is so much easier =) .. So I can use this big time for the second tank..
Guessing it won't be an issue having two of these on the same app.. Or will there be an issue? Most likely gonna just keep the main tank going with the standard wifi for now but curious if it is possible with the u app..
Shoot me a Pm or whatever with an Eta for the next shipment I'll grab one ASAP..
With this attachment can I upload code with out having to tether a cable to the reef angel from my laptop?
If so can you let me know when they are in, I'd like to order this with the salinity expansion
No, you need the bluetooth attachment to do that.
http://forum.reefangel.com/viewtopic.php?f=3&t=3372
Can we expect code uploads via the device someday?
I think that's one thing I would really like... Though I have gotten to the point where my reef tank setup is simple enough I don't need to change anything... lol
I could happen. I don't think there is anything out there yet to leverage so we would need to replicate the STK500v2 protocol on the cloud wifi attachment to be able to upload remotely.
I'm not sure what is going on, but I've had the cloud wifi app for a couple months now and it has started going to a solid green light from the blue connected light. Nothing has changed in setup or placement of it or the wifi router. I check the pins and everything is fine. It's on the side of the tank, so no moisture to speak of. I've been having to unplug it and re plug it back in. Sometime I have to do that a couple times before it reconnects. It is 12-15' away from the router
Do you have a computer that you can connect to the module and leave it logging to see what happens?
If so, connect the usb cable to the cloud wifi module and open Arduino. Then go to Tools->Serial monitor.
You should start seeing the log.
I will do that and post back. What I noticed is interesting is when it is connected after a while I go and check via the U-App and then it goes to green and eventually reconnects
PH:809
PH:808
PWMD:0
PWMA:38
PWMD:38
PWMA:0
PWMD:0
PWMA:38
PWMD:38
PWMA:0
PWMD:0
PWMA:38
PH:809
PH:808
PWMD:38
PWMA:0
PWMD:0
PWMA:38
PWMD:38
PWMA:0
PWMD:0
PWMA:38
PH:809
PH:808
PWMD:38
PWMA:0
PWMD:0
PH:809
PH:808
Connecting to Portal Server
Connected
Disconnecting from Portal Server
PWMD:38
PH:809
PH:808
T1:786
T1:784
T1:786
T1:784
all:0
ATOLOW:0
ATOHIGH:0
EM:0
EM1:2
REM:0
BID:1
AF:0
SF:0
PWMD:38
PWMA:0
PWMDO:255
PWMAO:255
R1:0
ROFF1:0
RON1:0
R2:0
ROFF2:0
RON2:0
R3:0
ROFF3:0
RON3:0
R4:0
ROFF4:0
RON4:0
R5:0
ROFF5:0
RON5:0
R6:0
ROFF6:0
RON6:0
R7:0
ROFF7:0
RON7:0
R8:0
ROFF8:0
RON8:0
ALARM:0
PWMD2:0
PWMA2:0
PWMD2O:0
PWMA2O:0
WL:0
WL1:0
WL2:0
WL3:0
WL4:0
HUM:0
DCM:5
DCS:38
DCD:50
DCT:20
PWME0:0
PWME1:0
PWME2:0
PWME3:0
PWME4:0
PWME5:0
PWME0O:0
PWME1O:0
PWME2O:0
PWME3O:0
PWME4O:0
PWME5O:0
AIW:0
AIB:0
AIRB:0
RFM:0
RFS:0
RFD:0
RFW:0
RFRB:0
RFR:0
RFG:0
RFB:0
RFI:0
RFWO:0
RFRBO:0
RFRO:0
RFGO:0
RFBO:0
RFIO:0
IO:0
LEAK:0
C0:0
C1:0
C2:0
C3:0
C4:0
C5:0
C6:0
C7:0
R:183
ROFF:66
RON:0
T1:784
T2:0
T3:0
PH:808
ORP:0
SAL:0
PHE:0
PAR:0
CEXP0:0
CEXP1:0
CEXP2:0
CEXP3:0
CEXP4:0
CEXP5:0
CEXP6:0
CEXP7:0
Connected
T1:786
T1:784
PWMA:20
Connected
T1:786
T1:784
T1:786
T1:784
PWMA:21
PWMA:22
PWMA:23
PWMA:24
PWMA:25
PWMA:26
PWMA:27
PWMA:28
PWMA:29
Connected
PWMA:30
PWMA:31
T1:786
T1:784
PWMA:32
PWMA:33
PWMA:34
T1:786
T1:784
PWMA:35
T1:786
T1:784
PWMA:36
T1:786
T1:784
PWMA:37
T1:786
T1:784
T1:786
T1:784
PWMA:38
PWMA:37
Connected
T1:786
MQTT Connecting...
MQTT failed
MQTT Connecting...
MQTT failed
MQTT Connecting...
MQTT failed
MQTT Connecting...
MQTT failed
MQTT Connecting...
MQTT failed
MQTT Connecting...
MQTT failed
MQTT Connecting...
MQTT failed
MQTT Connecting...
MQTT failed
MQTT Connecting...
MQTT failed
MQTT Connecting...
MQTT failed
MQTT Connecting...
MQTT failed
MQTT Connecting...
MQTT failed
MQTT Connecting...
MQTT failed
MQTT Connecting...
MQTT failed
MQTT Connecting...
MQTT failed
MQTT Connecting...
MQTT failed
MQTT Connecting...
MQTT failed
MQTT Connecting...
MQTT failed
MQTT Connecting...
MQTT failed
MQTT Connecting...
MQTT failed
MQTT Connecting...
MQTT failed
MQTT Connecting...
MQTT failed
MQTT Connecting...
MQTT failed
MQTT Connecting...
MQTT failed
MQTT Connecting...
MQTT failed
MQTT Connecting...
MQTT failed
MQTT Connecting...
MQTT failed
MQTT Connecting...
MQTT failed
Failed to connect
MQTT Connecting...
It does seem that it is loosing the connection and can't reconnect again for some reason.
Let me see if I can find anything with the firmware.
Thank you Rimai. Most of today it has not been connected, just blinking green. If it makes any difference I had used the webwizard to program the reef angel plus.
Hi. What Router are you using?slm222 wrote:Thank you Rimai. Most of today it has not been connected, just blinking green. If it makes any difference I had used the webwizard to program the reef angel plus.
I has a lot of the problems with one mikrotik Router. I changed that so everything are working fine.. if you can only test with another Router.
Regards from Argentina.
Cheers
Enviado desde mi Nexus 5 mediante Tapatalk
See if this code makes any difference.
Be aware that you will need to copy and paste the last 3 lines of the code to match whatever you have from your own code that you generated from the webwizard.
#include <SPI.h>
#include <WiFi101.h>
#include <PubSubClient.h>
#include <RA_CustomSettings.h>
//char ssid[32];
//char pass[32];
//char username[16];
//char password[16];
unsigned long client_timeout = millis();
unsigned long wifi_connection = millis();
unsigned long serial_timeout = millis();
unsigned long led_blink = millis();
unsigned long MQTTReconnectmillis = millis();
boolean LED_status = false;
boolean PortalConnection = false;
boolean power_status = true;
boolean data_ready = false;
int status = WL_IDLE_STATUS;
int connection_counter=0;
WiFiServer server(2000);
WiFiClient client;
WiFiClient portalclient;
WiFiClient mqttclient;
void mqttcallback(char* topic, byte* payload, unsigned int length);
PubSubClient CloudClient(MQTTServer, MQTTPORT, mqttcallback, mqttclient);
String currentLine = ""; // make a String to hold incoming data from the client
void setup() {
Serial.begin(57600); // initialize serial communication
Serial1.begin(57600); // initialize serial communication
pinMode(5, OUTPUT); // set the LED pin mode
pinMode(6, OUTPUT); // set the LED pin mode
pinMode(7, OUTPUT); // set the LED pin mode
wdt_initialize();
wdt_enable();
void loop() {
wdt_reset();
status = WiFi.status();
while ( status != WL_CONNECTED) {
digitalWrite(5, false);
digitalWrite(6, true);
digitalWrite(7, false);
if (millis() - wifi_connection > 1000)
Serial.print("Attempting to connect to Network named: ");
Serial.println(WIFI_SSID); // print the network name (SSID);
if (WiFi.begin(WIFI_SSID, WIFI_PASS) == WL_CONNECTED)
server.begin(); // start the web server on port 2000
printWifiStatus(); // you're connected now, so print out the status
digitalWrite(6, false);
digitalWrite(7, true);
Serial.println("Not connected...");
wdt_reset();
client = server.available(); // listen for incoming clients
if (client) { // if you get a client,
Serial.println(F("new incoming client")); // print a message out the serial port
while (client.connected()) { // loop while the client's connected
if (millis() - client_timeout > 2000) client.stop();
if (client.available()) { // if there's bytes to read from the client,
char c = client.read(); // read a byte, then
Serial.write(c); // print it out the serial monitor
Serial1.write(c); // send to Reef Angel
if (Serial1.available())
char c = Serial1.read();
//Serial.write(c);
currentLine += c;
if (currentLine.length() == 255) {
SendData();
if (millis() - serial_timeout > 400)
if (currentLine.length() > 0) {
SendData();
Serial.println();
client.println();
if (millis() - led_blink > 50)
LED_status = !LED_status;
digitalWrite(6, LED_status);
// close the connection:
client.stop();
Serial.println(F("incoming client disconnected"));
while (Serial1.available())
currentLine += c;
if(c==10) data_ready=true;
if (millis() - serial_timeout > 200 || data_ready)
data_ready=false;
// Serial.print(currentLine);
if (currentLine.startsWith("GET"))
PortalConnection = true;
Serial.println(F("Connecting to Portal Server"));
if (portalclient.connect(PortalServer, 80)) {
Serial.println(F("Connected"));
// Make a HTTP request:
portalclient.print(currentLine);
portalclient.println(F(" HTTP/1.1"));
portalclient.println(F("Host: forum.reefangel.com"));
portalclient.println(F("Connection: close"));
portalclient.println();
Serial.println(F("Failed to connect"));
if (currentLine.startsWith("CLOUD:"))
//Serial.print(currentLine);
if (currentLine.length() < 32)
if (CloudClient.connected())
//Serial.println(F("Publishing "));
currentLine.replace("CLOUD:", "");
char pub_buffer[sizeof(CLOUD_USERNAME) + 5];
sprintf(pub_buffer, "%s/out", CLOUD_USERNAME);
char pub_msg[currentLine.length() + 1];
currentLine.toCharArray(pub_msg, currentLine.length() + 1);
CloudClient.publish(pub_buffer, pub_msg);
Serial.print(F("Error on incoming data: "));
Serial.println(currentLine.length());
currentLine = "";
while (portalclient.available()) {
char c = portalclient.read();
// Serial.write(c);
if (PortalConnection && !portalclient.connected()) {
// Serial.println();
Serial.println(F("Disconnecting from Portal Server"));
portalclient.stop();
CloudClient.loop();
if (millis() - MQTTReconnectmillis > 5000)
if (!CloudClient.connected())
char sub_buffer[sizeof(CLOUD_USERNAME) + 6];
Serial.println(F("MQTT Connecting..."));
Serial.print(F("Attemp: "));
Serial.println(++connection_counter);
if (connection_counter>5)
Serial.println(F("Unable to connect. Rebooting..."));
digitalWrite(5, true);
while(1);
sprintf(sub_buffer, "RA-%s", CLOUD_USERNAME);
if (CloudClient.connect(sub_buffer, CLOUD_USERNAME, CLOUD_PASSWORD))
sprintf(sub_buffer, "%s/in/#", CLOUD_USERNAME);
Serial.println(F("MQTT succeeded"));
CloudClient.subscribe(sub_buffer);
Serial.println(F("MQTT failed"));
CloudClient.disconnect();
if (analogRead(0) < 600 && power_status)
power_status = false;
if (analogRead(0) > 600 && !power_status)
void SendData()
currentLine = "";
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
Serial1.print("cloud:");
for (int a=0;a<length;a++)
Serial1.write(payload[a]);
Serial.write(payload[a]);
Serial1.print(" ");
Serial.println();
void wdt_initialize()
GCLK->GENDIV.reg = GCLK_GENDIV_ID(2) | GCLK_GENDIV_DIV(4);
GCLK->GENCTRL.reg = GCLK_GENCTRL_ID(2) |
GCLK_GENCTRL_GENEN |
GCLK_GENCTRL_SRC_OSCULP32K |
GCLK_GENCTRL_DIVSEL;
while (GCLK->STATUS.bit.SYNCBUSY); // Syncronize write to GENCTRL reg.
GCLK->CLKCTRL.reg = GCLK_CLKCTRL_ID_WDT |
GCLK_CLKCTRL_CLKEN |
GCLK_CLKCTRL_GEN_GCLK2;
void wdt_enable()
WDT->CTRL.reg &= ~WDT_CTRL_ENABLE;
while (WDT->STATUS.bit.SYNCBUSY); // Syncronize write to CTRL reg.
WDT->CONFIG.reg = WDT_CONFIG_PER(0xA); // 0xA = 8192 ms
while (WDT->STATUS.bit.SYNCBUSY); // Syncronize write to CONFIG reg.
WDT->INTENCLR.reg |= WDT_INTENCLR_EW;
WDT->CTRL.reg |= WDT_CTRL_ENABLE;
void wdt_disable()
void wdt_reset()
WDT->CLEAR.reg = WDT_CLEAR_CLEAR_KEY;
while (WDT->STATUS.bit.SYNCBUSY); // Syncronize write to CLEAR reg.
// RA_STRING1=U2FsdGVkX19hO6KSSw/SEWReqPKC34stYAL4B8vahEY=
// RA_STRING2=U2FsdGVkX1+BPena6vAB/qszbCcvez8FgwKcXXxBbYg=
// RA_STRING3=test
I am using an ASUS router, but no changes have been made and the intermittent issues started out of now where. I have a Linksys AC2400 coming in to try that as well.LucianoB wrote:Hi. What Router are you using?slm222 wrote:Thank you Rimai. Most of today it has not been connected, just blinking green. If it makes any difference I had used the webwizard to program the reef angel plus.
Cheers
