Jebao Custom programming help
GugsJr
I need help programming my Jebaos. I have 3 and currently I have them on reefcrest mode.
I need help adding the following:
1. Turning off the Jeabos on Dimming Channel 0 and Channel 2 during feed mode
2. Jeabo on Dimming channel 1 to go into nutrient transport mode
3. I want each Jeabo to randomly select a different mode randomly every hour from 3pm to Midnight with random times where they aren't running for about 10 minutes.
4. The Jebaos from Midnight - 3pm to go to 10% and randomly turn off for 5 minutes
Below is my current code. I have it in the memory so I can change things from my phone. I only have a few items that I changed because I wanted my moonlights to only be on until 3am. Not opposite of the of the daylights. Also I wanted my fans to turn on a bit before my lights and after the moonlights.
Thank you
ReefAngel.FeedingModePortsE[0] = Port2Bit;
ReefAngel.WaterChangePorts = Port6Bit;
ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port4Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port6Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port3Bit | Port4Bit | Port5Bit;
ReefAngel.DayLights( Port2 );
ReefAngel.StandardLights( Port3,23,55,3,0 );
ReefAngel.StandardLights( Port7,14,55,3,0 );
ReefAngel.StandardHeater( Box1_Port3 );
ReefAngel.StandardHeater( Box1_Port5 );
ReefAngel.StandardATO( Box1_Port6 );
ReefAngel.MoonLights( Box1_Port7 );
ReefAngel.DCPump.ExpansionChannel[0] = Sync;
ReefAngel.DCPump.ExpansionChannel[1] = Sync;
ReefAngel.DCPump.ExpansionChannel[2] = AntiSync;
ReefAngel.Portal( "XXX" );
ReefAngel.DDNS( "XXX" ); // Your DDNS is XXX-XXX.myreefangel.com
Thank you
GugsJr
Re: Jebao Custom programming help
Is what I'm trying to do possible?
Aren't they going to 0 on feeding mode already?
This is supposed to turn them to 0:
GugsJr
Rimai, They do. But I want one of them to stay on. The one on dimming port 1 to go into nutrient transport mode.
I'm also trying to get each to do a different mode every hour for a certain time. With brief periods of turning off.
Start with this on loop() section.
I used this code, with different modes though.
if (ReefAngel.DisplayedMenu!=FEEDING_MODE || ReefAngel.DisplayedMenu!=WATERCHANGE_MODE)
if (hour()>=15 && hour()<=18)
ReefAngel.DCPump.SetMode(ShortWave,100,50 );
else if (hour()>=22 || hour()<=7)
ReefAngel.DCPump.SetMode(NutrientTransport,100,50 );
GugsJr
Thank you for that can you explain this line please. I'm trying to learn how to code in here. I know if and then statements for general coding but trying to learn the language in reef angel.
GugsJr
This is what I came up with not sure if it will work.
static int rmode;
byte modes[] = { ReefCrest, Lagoon, Constant, TidalSwell, ShortPulse, LongPulse, Else, Gyre };
if (now()%3600==0 || changeMode==true) { // Change at midnight or if controller rebooted
changeMode=false;
static unsigned long feeding;
if (now()-feeding<3600) {
} else if (now()%SECS_PER_DAY<43200 || now()%SECS_PER_DAY>=79200) { // 12pm / 10pm
// Night mode (go to 5%)
ReefAngel.DCPump.Speed=20;
ReefAngel.DCPump.Mode=modes[rmode]; // Put the mode to the random mode
} else {
static int rmode;
changeMode=false;
} else {
You added more stuff to your code than what I gave you.
One may override the other.
else if (hour()>=22 || hour()<=7) means if the first condition is not true, then it will check if hour is greater than or equal to 22 hours (10pm) or hour is less than or equal to 7 hours.
GugsJr
That's what I thought. I need to weed through it some more.
GugsJr
So the longer version I came up with didn't work the way I thought.
Then I tried the one below and it didn't work either. All the pumps went off, the one I wanted to wouldn't stay on. I hate to bother you with this. Is there a tutorial for programming?
ReefAngel.Portal( "GugsJr" );
ReefAngel.DDNS( "Home" ); // Your DDNS is GugsJr-Home.myreefangel.com
