Cloud Wifi Attachment
PostPosted: Mon Jan 02, 2017 4:40 pm
Hey guys,
I just released the cloud wifi attachment in the webstore.
This new wifi attachment has the ability to connect to our new cloud server and provide live feed of your parameters without the need to refresh to grab parameters or relay changes.
Use the web based Uapp to connect to the cloud server.
No more hassle of setting up port forwarding to get control of your Reef Angel Controller.
With the new cloud wifi attachment, you can be always connected to your controller wherever you are.
I have temporarily setup a controller for you to get a taste of what it can do:
1. Go to web based Uapp: uapp
2. Click "Settings" on the bottom bar
3. Click "Add controller" button
4. Enter the following:
IP Address: Leave blank
Port: Leave blank
Username: cloudwifi
Password: 123456
5. Click "Save" button.
6.Click "Relay" on the bottom bar. You should start seeing the relay changing status from red to green and vice-versa. It should update every 5 seconds as I setup to turn on/off every 5 seconds.
7. Click "Status" on the bottom bar. You should start seeing the parameters changing. This one may take a few seconds to update as temperature and humidity don't change that often and there is no pH probe, so it is just floating readings.
Let me know what you think :)
PostPosted: Mon Jan 02, 2017 5:12 pm
I like it !
PostPosted: Tue Feb 28, 2017 3:55 am
curious what makes the cloud wifi attachment better than the wifi attachment
PostPosted: Wed Mar 01, 2017 5:40 pm
The APP will be realtime and not require Refresh-ing
PostPosted: Thu Mar 02, 2017 4:46 am
Roberto, did you ever get the app working with this?
PostPosted: Thu Mar 02, 2017 9:27 am
Yes, the web based uapp should be fully functional.
Can you try it out and confirm?
PostPosted: Thu Mar 02, 2017 12:11 pm
Yep, it's working. I tried it on a generic Android 5 tablet, my Samsung 6.0.1 tablet, and my Pixel XL Android 7.1.1. All working fine using Chrome. Awesome!
How about the ability to set memory locations? That's really the only thing missing now.
PostPosted: Thu Mar 02, 2017 12:12 pm
That should be working too.
PostPosted: Thu Mar 02, 2017 12:15 pm
Sorry, I meant custom memory locations.
PostPosted: Thu Mar 02, 2017 12:27 pm
I still have to work on that
Next
Return to Addons
