I just purchased the dimming expansion module and I keep getting Bus Locks but not til after a few hours. This morning I woke up and had a bus lock. I unplugged the dimming module and the RA started working again.
What would cause this? Is it the cable or the module itself?
Also I can hear my relays randomly clicking and I don't have a wavemaker setting on any ports. The are either always on or always off with the exception of my ATO Pump,Lights and heaters.
Here is a list of my equipment.
RA+
Expansion Hub
Dimming Expansion
Relay Expansion
Main Relay
pH probe
Temp probe
Bus Lock from new dimming expansion
Re: Bus Lock from new dimming expansion
Try a different port in the hub.
Does it make any difference?
I switched both the Dimming Expansion and the Relay expansion into different ports and so far so good
That worked
Just got another Bus lock
You wouldn't happen to have a LEDs and T5's, would you?
I have all LEDs on LDD drivers. Roberto helped me find the problem. I was extending the VGA cables from the reef angel head unit to the main relay box, then extending the expansion relay to the secondary relay box.
This was creating interference
