Cloud Wifi Attachment
PostPosted: Thu Mar 02, 2017 5:10 pm
Any idea when it will be back in stock Roberto?
PostPosted: Fri Mar 10, 2017 8:29 pm
I just ordered mine!
is the controller moving away from the desktop app for uploading code and going to the web based app from now on?
PostPosted: Fri Mar 10, 2017 9:41 pm
That's the plan.
It's much easier to get updates to the wizard.
PostPosted: Tue Mar 14, 2017 2:19 pm
I got it in and working. I am running into two issues after switching it out and using the iphone app
1. I changed my labels, below, and now they are not showing up on my reef angel screen and on the uapp when i click download from portal it is pulling the old labels.
    ReefAngel.CustomLabels[0]="OPEN"; //1
    ReefAngel.CustomLabels[1]="Skimmer"; //2
    ReefAngel.CustomLabels[2]="FugeLight"; //3
    ReefAngel.CustomLabels[3]="Heater"; //4
    ReefAngel.CustomLabels[4]="OPEN"; //5
    ReefAngel.CustomLabels[5]="OPEN"; //6
    ReefAngel.CustomLabels[6]="ATO"; //7
    ReefAngel.CustomLabels[7]="OPEN"; //8
2. i changed my settings on the iphone app to the cloud server with correct password and username and it just keeps saying connecting
PostPosted: Tue Mar 14, 2017 6:50 pm
RA cannot download labels.
You need to change them in the code.
You can only download labels in the iphone app that you have setup on the portal.
So, the portal and the uapp share the same labels, but the ones in the screen need to be setup on your code.
The problem is that I think I screwed it up.
I changed the custom lables on the new libraries to be pulled from flash instead of using up RAM memory to avoid RAM memory usage, which was causing undesirable results.
When I created the web wizard, which uses the new libraries, I didn't give you the ability to change them :(
The iphone uapp also needs to be updated to be able to connect to the cloud server. We have not released the update yet.
The only way to get the cloud server connection is to use the web based uapp: uapp
I wanted to make sure the framework was good before I release a new update for iphone.
PostPosted: Tue Mar 14, 2017 8:18 pm
Thanks for the quick reply. And a big 10/4 on the future app release. That code above is from my sketch loaded with the web-based loader. With that it's not showing up in the display. Do I need to do something different?
PostPosted: Tue Mar 14, 2017 11:41 pm
Add me to the list of wanting to order one as soon as they are available.
I have my raceway in my garage on an RA without any means to add it to an app or control it, it's more of a monitoring thing due to my all in one xfinity gateway not allowing me to change internal port forwarding channels so I can only control one RA remotely. Was just thinking of bridging my router and buying a new better one just for the RA's but this is so much easier =) .. So I can use this big time for the second tank..
Guessing it won't be an issue having two of these on the same app.. Or will there be an issue? Most likely gonna just keep the main tank going with the standard wifi for now but curious if it is possible with the u app..
Shoot me a Pm or whatever with an Eta for the next shipment I'll grab one ASAP..
PostPosted: Wed Mar 22, 2017 9:39 am
With this attachment can I upload code with out having to tether a cable to the reef angel from my laptop?
If so can you let me know when they are in, I'd like to order this with the salinity expansion
PostPosted: Wed Mar 22, 2017 10:33 am
No, you need the bluetooth attachment to do that.
viewtopic.php?f=3&t=3372
PostPosted: Mon May 08, 2017 9:35 am
Can we expect code uploads via the device someday?
I think that's one thing I would really like... Though I have gotten to the point where my reef tank setup is simple enough I don't need to change anything... lol
PreviousNext
Return to Addons
Users browsing this forum: No registered users and 10 guests
