Icecap battery backup feeding mode code
kirkwood
I just picked up an icecap bsttery backup for a jebao pump and when i enter feeding or water change mode this signals the battery to kick on.
Is the fix just as simple as changing the code to speed 0 instead of turning the relay off? Does the PH need to be connected to the controller via the jebao cable for this to work? I have the cable but im currently running it via the jebao control unit.
Thx
Thx
GugsJr
Re: Icecap battery backup feeding mode code
Could you post your code?
kirkwood
It is just the standard Relay off type code for feeding mode and waterr change mode.
kirkwood
ReefAngel.FeedingModePorts = Port5Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port6Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port5 );
ReefAngel.DosingPumpRepeat( Port3,0,120,224 ); // dose ALK 224 seconds 12x/day
ReefAngel.DosingPumpRepeat( Port4,60,120,300 ); // dose CAL 300 seconds 12x/day
ReefAngel.StandardHeater( Port6,770,773 );
ReefAngel.StandardATO( Port7,900 );
//Start Feeding Mode at 20:30 - NONE
if ( (now()%86400==73800) ) {
ReefAngel.FeedingModeStart();
//Track ALK, CAL, and ATO dosing pumps
const byte numPumps=3;
byte pump[numPumps] = { Port3, Port4, Port7 };
byte portalMinutes[numPumps] = { 0, 2, 4 };
byte portalSeconds[numPumps] = { 1, 3, 5 };
static time_t pumpTimer[numPumps];
static boolean pumpStatus[numPumps];
static boolean atoDisabled;
for (int i=0;i< numPumps;i++) {
if (ReefAngel.Relay.Status(pump)) {
if (!pumpStatus) {
pumpTimer=now()-pumpTimer; // Pump was off, timer is now a time
pumpStatus=true;
} else {
if (pumpStatus) {
pumpTimer=now()-pumpTimer; // Pump was on, timer is now a timer
pumpStatus=false;
// Normalize and assign to CustomVar for reporting on the portal
ReefAngel.CustomVar[portalMinutes]=pumpTimer[i]/60; // Number of Minutes
// ReefAngel.CustomVar[portalSeconds[i]]=pumpTimer[i]%60; // Number of Seconds
static boolean clearTimer;
if (now()%SECS_PER_DAY!=SECS_PER_DAY-1) clearTimer=true;
if ( (now()%SECS_PER_DAY==SECS_PER_DAY-1) && clearTimer==true) {
// Backup timers to portal variable
ReefAngel.CustomVar[portalSeconds[0]] = pumpTimer[0]/60;
ReefAngel.CustomVar[portalSeconds[1]] = pumpTimer[1]/60;
ReefAngel.CustomVar[portalSeconds[2]] = pumpTimer[2]/60;
pumpTimer[0]=0; // Clear timer for Port3
pumpTimer[1]=0; // Clear timer for Port4
clearTimer=false;
if (bitRead(ReefAngel.Relay.RelayMaskOn, 6)==1) { // ATO relay was forced on
atoDisabled=true; // don't want to change the variable names yet.. but you may want to to make it clearer..
if (atoDisabled && (bitRead(ReefAngel.Relay.RelayMaskOn, 6)==0)) { // ATO override has been cleared
pumpTimer[2]=0; // Clear timer for ATOPort
atoDisabled=false;
ReefAngel.Relay.Set(Port5,now()%19800!=0);
if (hour()>=7 && hour()<8)
ReefAngel.PWM.SetDaylight( LongPulseMode(40,55,10,true) ); // Long pulse hi/low 60%40% 10s pulse on sync mode
ReefAngel.PWM.SetActinic( LongPulseMode(40,55,10,false) ); // Long pulse hi/low 60%40% 10s pulse on anti-sync mode
else if (hour()>=8 && hour()<11)
ReefAngel.PWM.SetDaylight( NutrientTransportMode(0,75,700,true) ); // NTM low/high 30%90% on sync mode
ReefAngel.PWM.SetActinic( NutrientTransportMode(0,75,700,false) ); // NTM low/high 30%90% on anti-sync mode
else if (hour()>=11 && hour()<14)
ReefAngel.PWM.SetDaylight( ShortPulseMode(0,50,230,true) ); // Short pulse at 60% with 200ms pulse on sync mode
ReefAngel.PWM.SetActinic( ShortPulseMode(0,50,230,false) ); // Short pulse at 60% with 200ms pulse on anti-sync mode
else if (hour()>=14 && hour()<16)
ReefAngel.PWM.SetDaylight( ReefCrestMode(60,25,true) ); // ReefCrest on 50% with +/-10% on sync mode
ReefAngel.PWM.SetActinic( ReefCrestMode(60,25,false) ); // ReefCrest on 50% with +/-10% on sync mode
else if (hour()>=16 && hour()<18)
ReefAngel.PWM.SetDaylight( NutrientTransportMode(0,65,700,true) ); // NTM low/high 30%90% on sync mode
ReefAngel.PWM.SetActinic( NutrientTransportMode(0,65,700,false) ); // NTM low/high 30%90% on anti-sync mode
else if (hour()>=18 && hour()<20)
ReefAngel.PWM.SetDaylight( TidalSwellMode(70,true) ); // TidalSwell at 70% on sync mode
ReefAngel.PWM.SetActinic( TidalSwellMode(70,false) ); // TidalSwell at 70% on anti-sync mode
else if (hour()>=20 && hour()<23)
ReefAngel.PWM.SetDaylight( ShortPulseMode(0,65,900,true) ); // Short pulse at 60% with 200ms pulse on sync mode
ReefAngel.PWM.SetActinic( ShortPulseMode(0,65,900,false) ); // Short pulse at 60% with 200ms pulse on anti-sync mode
ReefAngel.Portal( "kirkwood" );
if (!pumpStatus) {
pumpStatus=true;
} else {
if (pumpStatus) {
pumpStatus=false;
clearTimer=false;
atoDisabled=false;
kirkwood
I tried tweaking my code from other users posts but still need help. I went ahead and removed the Jebao port (Port 5) from turning off on water change or feeding mode. Now I just need an "if" statement that puts the Port 5 speed at 0 whenever feeding mode or water change mode are activated.
Thanks.
my attempt and fail..
ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.PWM.FeedingSpeed=0;
ReefAngel.PWM.WaterChangeSpeed=0;
Thanks.
GugsJr
kirkwood
Doesn't work. There is nothing specified as "DCPump" anywhere in my code.GugsJr wrote:// Feeeding and Water Change mode speed
GugsJr
how do you have your Jebaos hooked up? On the original switch?
kirkwood
I dont know how to answer that question. I dont write code and honestly havent touched my RA code in almost 2 years. My full code is posted above.GugsJr wrote:how do you have your Jebaos hooked up? On the original switch?
kirkwood
Anyone else know the code to make port 5 run at speed 0 when i activate feeding or waterchange mode? I need to make this change because i just added an icecap batterybackup and currently when port 5 turns off in feeding mode it triggers the icecap to turn on thinking there has been a poeer outage.
GugsJr
try this. I simplified it from the previous code I typed
feeding = now();
ReefAngel.PWM.SetDaylight( 0 );
ReefAngel.PWM.SetActinic( 0 );
else if (hour()>=7 && hour()<8)
feeding = now();
kirkwood
I tried that but it gave an error for this line
feeding = now();
I went back to your original recommendation but added "#include <DCPump.h>"
that allowed the code below to pass the verification test
the problem is that it does NOT turn the jebao speed on Port 5 to zero. I also tried defining Port 5 as part of Feeding and water change mode however that also didn't work.
if (!pumpStatus) {
pumpStatus=true;
} else {
if (pumpStatus) {
pumpStatus=false;
clearTimer=false;
atoDisabled=false;
ReefAngel.PWM.SetDaylight( SineMode(30,70,300,true) ); // Sine mode low/hi 40%95% on 5 minute cycle on sync mode
ReefAngel.PWM.SetActinic( SineMode(30,70,300,false) ); // Sine mode low/hi 40%95% on 5 minute cycle on anti-sync mode
ReefAngel.PWM.SetDaylight( ShortPulseMode(0,60,230,true) ); // Short pulse at 60% with 200ms pulse on sync mode
ReefAngel.PWM.SetActinic( ShortPulseMode(0,60,230,false) ); // Short pulse at 60% with 200ms pulse on anti-sync mode
else if (hour()>=18 && hour()<21)
else if (hour()>=21 && hour()<23)
feeding = now();
if (!pumpStatus) {
pumpStatus=true;
} else {
if (pumpStatus) {
pumpStatus=false;
clearTimer=false;
atoDisabled=false;
kirkwood
Try this:
if (ReefAngel.DisplayedMenu==FEEDING_MODE || ReefAngel.DisplayedMenu==WATERCHANGE_MODE)
ReefAngel.PWM.SetActinic( 0);
kirkwood
This still did not prevent the icecap backup battery from kicking on and running the jebao on Port5... I also tried removing Port5 from the feeding mode and waterchange mode "Off" list but that didn't work either...
//Jebao speed 0 on feeding/water change modes to prevent Icecap battery from turning on
if (ReefAngel.Relay.Status(pump[i])) {
if (!pumpStatus[i]) {
pumpStatus[i]=true;
} else {
if (pumpStatus[i]) {
pumpStatus[i]=false;
ReefAngel.CustomVar[portalMinutes[i]]=pumpTimer[i]/60; // Number of Minutes
clearTimer=false;
atoDisabled=false;
ReefAngel.PWM.SetDaylight( ShortPulseMode(0,80,500,true) ); // Short pulse at 60% with 200ms pulse on sync mode
ReefAngel.PWM.SetActinic( ShortPulseMode(0,80,500,false) ); // Short pulse at 60% with 200ms pulse on anti-sync mode
else if (hour()>=20 && hour()<21)
ReefAngel.PWM.SetDaylight( ShortPulseMode(0,80,500,true) ); // TidalSwell at 70% on sync mode
ReefAngel.PWM.SetActinic( ShortPulseMode(0,80,500,false) ); // TidalSwell at 70% on anti-sync mode
ReefAngel.PWM.SetDaylight( ShortPulseMode(0,50,300,true) ); // Short pulse at 60% with 200ms pulse on sync mode
ReefAngel.PWM.SetActinic( ShortPulseMode(0,50,300,false) ); // Short pulse at 60% with 200ms pulse on anti-sync mode
kirkwood
I got it to work. Roberto I just had to move your code down to my PWM if/else statements...
