New cloud Wifi wont connect
benjy1234
Post by benjy1234 »
I went through the manual and followed all the procedures and everything went okay until I plug the module into the RA. It just slowly blinks green and wont connect. I made a new code through the web wizard and just copied over my old code to the corresponding areas leaving the meat of the new code intact. I figured that may be the issue but now when I try to just create a new code the webwizard wont generate one, it just generates this;
void setup() {
// put your setup code here, to run once:
void loop() {
// put your main code here, to run repeatedly:
Im sure im doing something stupid. Any ideas?
benjy1234
Re: New cloud Wifi wont connect
Post by benjy1234 »
Anybody have any ideas??? Im pulling my hair out here trying to get this thing to connect. It connects when I plug it into my computer but just sits at green status on the RA????
Humm.
Interesting.
Try this.
Use a usb adapter to power the cloud wifi attachment.
Does it connect?
If it does connect, plug into RA while it is still connected.
Does it keep the connection?
Unplug the usb cable.
benjy1234
Post by benjy1234 »
Holy cow that worked lol. Thanks Roberto!!
