Hi, I receive my Cloud WIFI Add-on, I followed the PDF Manual step by step but when I try compile the Code Generated by Webwizard for my RA+, not for my Cloud Wifi (I already did that), I received this message Error compiling: [object Object] .... Does anyone know I'm doing wrong?
Regards,
Wifi Cloud Configuration
LucianoB
Re: Wifi Cloud Configuration
This code was 100% generated by webwizard
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit;
InternalMemory.OverheatTemp_write( 290 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( T1_PROBE,Port2,255,260 );
ReefAngel.StandardFan( T1_PROBE,Port3,275,260 );
ReefAngel.StandardLights( Port4,10,0,21,0 );
ReefAngel.Wavemaker( Port5,59 );
ReefAngel.PWM.SetDaylight( PWMParabola( 10,0,20,0,15,70,0 ) );
ReefAngel.PWM.SetActinic( PWMParabola( 10,0,20,0,15,28,0 ) );
ReefAngel.CloudPortal();
rimai wrote:Can you post the code you are trying to compile?
I'm able to compile this code.
Can you post the entire error log that you get?
LucianoB
Hi Roberto, forget...I retried today and worked fine. I don't know what happened. I will do the next step...if I have any other problem, I will contact to you.
Really apreciated your time.
Cheers from Argentina!
