Wifi Cloud Configuration
LucianoB
Post by LucianoB »
Hi, I receive my Cloud WIFI Add-on, I followed the PDF Manual step by step but when I try compile the Code Generated by Webwizard for my RA+, not for my Cloud Wifi (I already did that), I received this message Error compiling: [object Object] .... Does anyone know I'm doing wrong?
Regards,
Re: Wifi Cloud Configuration
Can you post the code you are trying to compile?
LucianoB
Post by LucianoB »
This code was 100% generated by webwizard
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 290 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( T1_PROBE,Port2,255,260 );
ReefAngel.StandardFan( T1_PROBE,Port3,275,260 );
ReefAngel.StandardLights( Port4,10,0,21,0 );
ReefAngel.Wavemaker( Port5,59 );
ReefAngel.PWM.SetDaylight( PWMParabola( 10,0,20,0,15,70,0 ) );
ReefAngel.PWM.SetActinic( PWMParabola( 10,0,20,0,15,28,0 ) );
ReefAngel.CloudPortal();
rimai wrote:Can you post the code you are trying to compile?
I'm able to compile this code.
Can you post the entire error log that you get?
LucianoB
Post by LucianoB »
Hi Roberto, forget...I retried today and worked fine. I don't know what happened. I will do the next step...if I have any other problem, I will contact to you.
Really apreciated your time.
Cheers from Argentina!
