Hi guys/girls,
It has been more than a year that I have used the portal or checked the readings on the controller as it has been working flawlessly for the past few years, no changes needed.
The apps however never worked for me, don't know why.
So out of curiosity i checked the portal and found out that the portal reading of the waterlevel is 21%, the controller however says 99%. All other readings are the same (and correct) on both portal and controller.
Is there something that I need to do to let the portal display the correct value?
Your input is much appreciated.
Leslie
Waterlevel reading in portal is different from controller
lmolenmaker
Re: Waterlevel reading in portal is different from controlle
Update the firmware of the wifi attachment:
