Ro Dump and Membrane flush
PostPosted: Sat Apr 22, 2017 6:40 pm
I would like some help with dumping RO output to drain (Port#X 12V wall wort to solenoid) before it hits the DI resin. The dump would start with an ATO low trigger and would need to run for about a minute to drop the TDS down to 1 or 2. It would cut off after the timer was done.
I would also like to trigger a port to flush the RO membrane via a timer, it would trigger every hour for around 3 minutes or so.
Also is there a way to increase the ATO timeout? I have it at 600 now which seems to be the max?
I need to start tinkering again with the code, I learned all this 5 years ago and everything has been rock solid. I just want to get back into it and refine some things! Thanks
PostPosted: Sun Apr 23, 2017 12:04 pm
Also where can I find the web generator?
PostPosted: Sun Apr 23, 2017 4:01 pm
Web wizard:
viewtopic.php?f=8&t=6199
Try this:
static unsigned long mytimer=0;
static boolean timeractive=false;
if (ReefAngel.LowATO.IsActive() && !timeractive) // If Low ATO is triggered
  timeractive=true;
  mytimer=now();
ReefAngel.Relay.Set(Port1,(now()-mytimer)<60)); // Port 1 for 1 minute after Low ATO is triggered
ReefAngel.Relay.Set(Port2,(now()-mytimer)<180)); // Port 2 for 3 minutes after Low ATO is triggered
if (!ReefAngel.LowATO.IsActive()) timeractive=false; // Wait for Low ATO to deactivate and disable timer
PostPosted: Sun Apr 23, 2017 7:30 pm
thanks! Do you think this would work? I would like low ato to trigger the solenoid on port 5 for 3 minutes, clearing the higher TDS from between the membrane and the DI cartridges. After which, turn off port five and turn on port 7 to fill the sump until the ATO deactivates. Im just not sure if I would need to nest the operations? I havent uploaded anything yet, I will be using the web wizard to do it though.
  //RO DUMP PRE DI
       timeractive=true;
       mytimer=now();
     ReefAngel.Relay.Set(Port5,(now()-mytimer)<180)); // Port 5 for 3 minute after Low ATO is triggered
     then
     ReefAngel.Relay.Set(Port7,(now()-mytimer)<180)); // Port 7 (until Low ATO is deactivated); after Port 5 is triggered
Return to How do I code ...
