Web wizard
Reeflife916
Web wizard
I have switched over to using the web wizard, but i am having problems. When trying to generate a code, once i have programmed everything, i go to hit generate and all it gives me is a blank code. If i try to upload this, the controller has a blacked out screen.
The reason for me using web wizard instead or arduino, is that i recently bought the cloud wifi attachment, and arduino is not showing it as an option while using the arduino wizard. Can anybody help with getting my cloud wifi to work?
Reeflife916
Re: Web wizard
I tried it in Firefox, Chrome, and microsoft edge, and still get the same result. This is the code it generates:
void setup() {
// put your setup code here, to run once:
void loop() {
// put your main code here, to run repeatedly:
void setup() {
void loop() {
Reeflife916
Re: Web wizard
Whats weird is that if I change all 8 ports to not used, it will than generate a normal looking code:
ReefAngel.FeedingModePorts = Port4Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port4Bit | Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit;
ReefAngel.CloudPortal();
// RA_STRING1=null
// RA_STRING2=null
// RA_STRING3=null
// RA_STRING1=null
// RA_STRING2=null
// RA_STRING3=null
Re: Web wizard
There may be a bug somewhere.
Can you try one port at a time and report which one is the one failing?
Reeflife916
Re: Web wizard
ok, so both ports 3 & 4 the ones causing the code not to generate. they were both time schedule. once I changed the function to always on, the code generated. But once I go to upload the code, it takes a long time, than gives an upload timeout error.
Reeflife916
Re: Web wizard
port 3, 12:00pm -9:00pm and port 4, 1:00pm - 9:00pm
This code below is the one I have always used and works great, I just want to add my new cloud wifi. Is there a way I can just add it into the sketch?
ReefAngel.StandardHeater( Port1,780,790 );
ReefAngel.StandardLights( Port2,12,0,21,0 );
ReefAngel.StandardLights( Port3,13,0,20,0 );
ReefAngel.Relay.DelayedOn( Port4,2 );
ReefAngel.Relay.DelayedOn( Port6,4 );
Re: Web wizard
Yeah.
You need to add this:
Just above ShowInterface()
Then, generate a code and copy the 3 bottom lines too.
They look like this:
Try that and let me know if you have problems compiling.
I was able to replicate the problem.
Thanks for reporting and troubleshooting:)
The timeout error is another issue.
Check if you are using the correct COM port.
// RA_STRING1=U2FsdGVkX1/SYcbxqia+Ctm9luLvQ1ZrEDcg2DDgO3k=
// RA_STRING2=U2FsdGVkX191TYz62vRRqpOWczR5eL/HX1DHEXNFSvY=
// RA_STRING3=testing2
Reeflife916
Re: Web wizard
Ok, so i got the web wizard to work by figuring out the correct com port, but the wifi still is not connecting to network. After i upload code to cloud wifi should the indicator light blue? Mine is a slow blink green
Reeflife916
Re: Web wizard
I am happy to report that it now generates with the time schedules. Also, I have my cloud wifi lit blue now, but for some reason I cannot see it in the portal or in the uapp
