wizard code error
aprilnicole30540
wizard code error
Post by aprilnicole30540 »
when I run through the wizard setup and go to generate the code it gives me errors class reefangleclass has no member named feeding mode portE and does the same for lights on mode, water change mode, overheat shutoff. I have to go in and delete the code for those and then it will compile. why is it doing this?
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <Salinity.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <PH.h>
#include <WaterLevel.h>
#include <Humidity.h>
#include <DCPump.h>
#include <PAR.h>
#include <ReefAngel.h>
////// Place global variable code below here
////// Place global variable code above here
    ReefAngel.AddPHExpansion(); // pH Expansion Module
    ReefAngel.WaterChangePorts = Port6Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port4Bit;
    ReefAngel.Relay.On( Port7 );
    ReefAngel.StandardLights( Port1,9,0,21,0 );
    ReefAngel.StandardLights( Port2,9,15,21,15 );
    ReefAngel.StandardATO( Port3,60 );
    ReefAngel.StandardHeater( Port4,779,780 );
Re: wizard code error
Because you chose the relay expansion module and never setup any of its ports.
jjdezek
Post by jjdezek »
Ok I thought that was the standard relay. Been awhile since I did the initial setup on one. If I delete the reefangel.feedingmodeportsE part of the code it should work fine correct?
That works too.
