My wifi module will not always stay connected. some time a reboot of the module will fix it, other times a reboot of the wifi router will. Is there a way to tell which is causing the problem?
riggeek
wifi module connection
riggeek
- Contact:
Re: wifi module connection
I have noticed if my wifi module stops responding one of the lights on it stays solid. that's my clue. I've never had to reboot my AP to get it to work. I just unplug and plug in the wifi module and it works.
I don't recall what light stays on either.
it's possible that you might need updated or different firmware on the wifi module.
riggeek
Binder
I will look into that.
only the green light is on solid.
riggeek
riggeek
riggeek
riggeek
I was able to connect to the WIFI model on com 4
tried to do a update.
it wanted me to disconnect and reconnect the cable.
I was able to do a factory reset.
then i reconnceted, but now it will not let me load my wifi setting.
It wants me to disconnect and reconnect the cable. I have tried this quite a few times with not luck.
any ideas.
riggeek
any ideas.
riggeek
riggeek
riggeek
Got Teraterm to work, and WiFi model is back online.
Just one question left.
How do I update the firmware with out it crashing again.
riggeek
riggeek
riggeek
If you got teraterm already, follow the steps in this thread:
riggeek
wifi is up and working good now.
Thanks for all the help.
riggeek
riggeek
riggeek
