Adding 2 more Jebao Cables
slm222
Post by slm222 »
Would it be possibly to splice the dimming cables in with the exsisting ones that are plugged into the relay dimming ports? Or should i just purchase another relay to have the extra plugs with the extra dimming ports?
Re: Adding 2 more Jebao Cables
The expansion box will not give you two more dimming ports.
You would need the dimming expansion module.
But I think splicing would work if you don't mind that they will run at the same time.
slm222
Post by slm222 »
Perfect. Yes I want 2 to be sync and 2 to be anti sync.
