Cloud Wifi Attachment
PostPosted: Wed May 31, 2017 1:42 pm
rimai wrote:See if this code makes any difference.
I will add this into my cloud device tonight. Thank you
This is your rewritten code with my info at the bottom i will add
#include <SPI.h>
#include <WiFi101.h>
#include <PubSubClient.h>
#include <RA_CustomSettings.h>
//char ssid[32];
//char pass[32];
//char username[16];
//char password[16];
unsigned long client_timeout = millis();
unsigned long wifi_connection = millis();
unsigned long serial_timeout = millis();
unsigned long led_blink = millis();
unsigned long MQTTReconnectmillis = millis();
boolean LED_status = false;
boolean PortalConnection = false;
boolean power_status = true;
boolean data_ready = false;
int status = WL_IDLE_STATUS;
int connection_counter=0;
WiFiServer server(2000);
WiFiClient client;
WiFiClient portalclient;
WiFiClient mqttclient;
void mqttcallback(char* topic, byte* payload, unsigned int length);
PubSubClient CloudClient(MQTTServer, MQTTPORT, mqttcallback, mqttclient);
String currentLine = "";                // make a String to hold incoming data from the client
void setup() {
  Serial.begin(57600);      // initialize serial communication
  Serial1.begin(57600);      // initialize serial communication
  pinMode(5, OUTPUT);      // set the LED pin mode
  pinMode(6, OUTPUT);      // set the LED pin mode
  pinMode(7, OUTPUT);      // set the LED pin mode
  wdt_initialize();
  wdt_enable();
void loop() {
  wdt_reset();
  status = WiFi.status();
  while ( status != WL_CONNECTED) {
    digitalWrite(5, false);
    digitalWrite(6, true);
    digitalWrite(7, false);
    if (millis() - wifi_connection > 1000)
      Serial.print("Attempting to connect to Network named: ");
      Serial.println(WIFI_SSID);                   // print the network name (SSID);
      if (WiFi.begin(WIFI_SSID, WIFI_PASS) == WL_CONNECTED)
        server.begin();                           // start the web server on port 2000
        printWifiStatus();                        // you're connected now, so print out the status
        digitalWrite(6, false);
        digitalWrite(7, true);
      Serial.println("Not connected...");
    wdt_reset();
  client = server.available();   // listen for incoming clients
  if (client) {                             // if you get a client,
    Serial.println(F("new incoming client"));           // print a message out the serial port
    while (client.connected()) {            // loop while the client's connected
      if (millis() - client_timeout > 2000) client.stop();
      if (client.available()) {             // if there's bytes to read from the client,
        char c = client.read();             // read a byte, then
        Serial.write(c);                    // print it out the serial monitor
        Serial1.write(c);                   // send to Reef Angel
      if (Serial1.available())
        char c = Serial1.read();
        //Serial.write(c);
        currentLine += c;
        if (currentLine.length() == 255) {
          SendData();
      if (millis() - serial_timeout > 400)
        if (currentLine.length() > 0) {
          SendData();
          Serial.println();
          client.println();
      if (millis() - led_blink > 50)
        LED_status = !LED_status;
        digitalWrite(6, LED_status);
    // close the connection:
    client.stop();
    Serial.println(F("incoming client disconnected"));
    while (Serial1.available())
      currentLine += c;
      if(c==10) data_ready=true;
      if (millis() - serial_timeout > 200 || data_ready)
          data_ready=false;
          //        Serial.print(currentLine);
          if (currentLine.startsWith("GET"))
            PortalConnection = true;
            Serial.println(F("Connecting to Portal Server"));
            if (portalclient.connect(PortalServer, 80)) {
              Serial.println(F("Connected"));
              // Make a HTTP request:
              portalclient.print(currentLine);
              portalclient.println(F(" HTTP/1.1"));
              portalclient.println(F("Host: forum.reefangel.com"));
              portalclient.println(F("Connection: close"));
              portalclient.println();
              Serial.println(F("Failed to connect"));
          if (currentLine.startsWith("CLOUD:"))
            //Serial.print(currentLine);
            if (currentLine.length() < 32)
              if (CloudClient.connected())
                //Serial.println(F("Publishing "));
                currentLine.replace("CLOUD:", "");
                char pub_buffer[sizeof(CLOUD_USERNAME) + 5];
                sprintf(pub_buffer, "%s/out", CLOUD_USERNAME);
                char pub_msg[currentLine.length() + 1];
                currentLine.toCharArray(pub_msg, currentLine.length() + 1);
                CloudClient.publish(pub_buffer, pub_msg);
              Serial.print(F("Error on incoming data: "));
              Serial.println(currentLine.length());
          currentLine = "";
    while (portalclient.available()) {
      char c = portalclient.read();
      //      Serial.write(c);
    if (PortalConnection && !portalclient.connected()) {
      //      Serial.println();
      Serial.println(F("Disconnecting from Portal Server"));
      portalclient.stop();
  CloudClient.loop();
  if (millis() - MQTTReconnectmillis > 5000)
    if (!CloudClient.connected())
      char sub_buffer[sizeof(CLOUD_USERNAME) + 6];
      Serial.println(F("MQTT Connecting..."));
      Serial.print(F("Attemp: "));
      Serial.println(++connection_counter);
      if (connection_counter>5)
        Serial.println(F("Unable to connect. Rebooting..."));
        digitalWrite(5, true);
        while(1);
      sprintf(sub_buffer, "RA-%s", CLOUD_USERNAME);
      if (CloudClient.connect(sub_buffer, CLOUD_USERNAME, CLOUD_PASSWORD))
        sprintf(sub_buffer, "%s/in/#", CLOUD_USERNAME);
        Serial.println(F("MQTT succeeded"));
        CloudClient.subscribe(sub_buffer);
        Serial.println(F("MQTT failed"));
        CloudClient.disconnect();
  if (analogRead(0) < 600 && power_status)
    power_status = false;
  if (analogRead(0) > 600 && !power_status)
void SendData()
  currentLine = "";
void printWifiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your WiFi shield's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
  Serial1.print("cloud:");
  for (int a=0;a<length;a++)
    Serial1.write(payload[a]);
    Serial.write(payload[a]);
  Serial1.print(" ");
  Serial.println();
void wdt_initialize()
  GCLK->GENDIV.reg = GCLK_GENDIV_ID(2) | GCLK_GENDIV_DIV(4);
  GCLK->GENCTRL.reg = GCLK_GENCTRL_ID(2) |
                      GCLK_GENCTRL_GENEN |
                      GCLK_GENCTRL_SRC_OSCULP32K |
                      GCLK_GENCTRL_DIVSEL;
  while (GCLK->STATUS.bit.SYNCBUSY);  // Syncronize write to GENCTRL reg.
  GCLK->CLKCTRL.reg = GCLK_CLKCTRL_ID_WDT |
                      GCLK_CLKCTRL_CLKEN |
                      GCLK_CLKCTRL_GEN_GCLK2;
void wdt_enable()
  WDT->CTRL.reg &= ~WDT_CTRL_ENABLE;
  while (WDT->STATUS.bit.SYNCBUSY);  // Syncronize write to CTRL reg.
  WDT->CONFIG.reg = WDT_CONFIG_PER(0xA);  // 0xA = 8192 ms
  while (WDT->STATUS.bit.SYNCBUSY);  // Syncronize write to CONFIG reg.
  WDT->INTENCLR.reg |= WDT_INTENCLR_EW;
  WDT->CTRL.reg |= WDT_CTRL_ENABLE;
void wdt_disable()
void wdt_reset()
  WDT->CLEAR.reg = WDT_CLEAR_CLEAR_KEY;
  while (WDT->STATUS.bit.SYNCBUSY);  // Syncronize write to CLEAR reg.
// RA_STRING1=U2FsdGVkX1+McuCAkIlSsRrljZrxqPemQeco0gw3Qh0=
// RA_STRING2=U2FsdGVkX182otKKK42E19GJNzbCmJB4k/bR5D12l+Q=
// RA_STRING3=Monroe
PostPosted: Wed May 31, 2017 4:53 pm
This looks really cool - but I'm not seeing a UApp for Android in the store but do see one in the iTunes store. Is there a plan to officially support Android?
PostPosted: Wed May 31, 2017 5:05 pm
The Uapp should be in the apple store, but it is an outdated version.
It was originally designed to be the Apple app and got migrated to a web based application since it is entirely created as a web application natively.
I can also post on the Android store too.
I'm just waiting to get all the bugs out before I released it on both stores. It's a pain to release to the stores :(
In the mean time, you can use the browser of your phone to make it work.
PostPosted: Wed May 31, 2017 5:49 pm
I have loaded the code and it has been in a state of trying to connect for an hr. constant solid currently. It owuld blink occasionally when i first plugged it in.
PostPosted: Wed May 31, 2017 5:51 pm
Can you pull log again?
PostPosted: Wed May 31, 2017 6:02 pm
Ok, I tried to pull a log and it would not show a COM port to allow me to select. I disconnected the device and replugged in with my computer and COM showed up, i think plugged into the reef angel and it is working now. I was trying to get back before you had read my inital response as a simple reset fixed it. I will keep monitoring it and report back.
Again Thank you for your promptness, we are soon to travel out of the country and not being able to see the tank was a bit worrying to me.
PostPosted: Wed May 31, 2017 7:46 pm
So something interesting is going on. and it had to do with the sequence of how i plugged the unit it. when i plug the unit into the reef angel it blinks green and goes solid green with an occasional blink, then when i plug into it with the computer to run the serial monitor the computer prompts that the usb was not recognized and disables and re-enables the port and at that point the wifi unit turns blue immediately and stays running. I unplugged the computer and it stayed blue, then after a while (longer than i know as i was not paying attention) the light completely turned off. Then the cycle starts over.
PostPosted: Thu Jun 01, 2017 11:50 am
I re uploaded as well reset the whole system and it is functioning now
PostPosted: Sun Jun 04, 2017 5:00 pm
This is going on with both the old and the new routers. With the modified code below i am getting "Attempting to connect to Network named:
Not connected..." on the serial monitor scrolling over and over. It is staying constant green. With the webwizard code it is connecting to the wifi and upload but only when i have the usb cable plugged into the side and plugged into the computer. as soon as i unplug it changes to teal for a couple seconds and then goes back to solid green and an occansional blink. when i plug the usb back in it states the usb is not recognized and then refreshes the connection itself by diconnecting and reconnecting and at that point it turns blue and acts normal.
*Edit: something interesting i just tried. i plugged the usb cable into the side of the wifi unit and then into the iphone wall charger. it started working with that plugged in as well and the webwizard code.... not sure what to make of that.
#include <SPI.h>
//char ssid[32];
//char pass[32];
WiFiClient client;
void setup() {
  wdt_initialize();
  wdt_enable();
void loop() {
  wdt_reset();
    wdt_reset();
        //Serial.write(c);
        currentLine += c;
          SendData();
          SendData();
          Serial.println();
          client.println();
    client.stop();
      currentLine += c;
          data_ready=false;
          currentLine = "";
      //      Serial.write(c);
  CloudClient.loop();
        while(1);
void SendData()
  currentLine = "";
  Serial.println(ip);
  Serial.print(rssi);
  Serial1.print(" ");
  Serial.println();
void wdt_enable()
void wdt_disable()
void wdt_reset()
// RA_STRING1=U2FsdGVkX1+AF2lnzKYQyNPLiQGZJdj0GFAKsjt2XXk=
// RA_STRING2=U2FsdGVkX1+K7xN24vw/vykDiKano9Ep9ArQL7gfcck=
PostPosted: Mon Jun 12, 2017 6:09 am
Anyone?
PreviousNext
Return to Addons
