Client Suite 3.0
PostPosted: Tue May 19, 2015 11:04 am
woohoo....and the silent man speaks. :-)
see, the interest is there and people are willing to help.
PostPosted: Sun Oct 18, 2015 8:08 am
Just fired it up, first issue was the scan didn't detect it in the internal address space.. Might be router settings, lmk if you need more info.
Nice slick setup so far :)
reef angel client suite wifi.jpg (79.45 KiB) Viewed 6470 times
PostPosted: Wed Jun 15, 2016 6:20 pm
I just recently got the RA setup and have been using the client for the past few days. I was curious if the issue in the attachment is related to something I've inadvertently done or just something with the client. If I did it, any idea how to reverse what I've done LOL? The issue is that I have a few lines of the same temp (e.g. two lines of 80°, two lines of 79° etc.). I end up with the same issue on the pH plots as well. If I open and close the app, occasionally I'll get something a little different. I've restarted the computer, stop/started the services etc. but nothing seems to correct it.
PostPosted: Sun Oct 30, 2016 7:51 pm
Just posting to say I really love this application and find it much quicker to use than the portal. I hope development can continue!
PostPosted: Sat Jan 21, 2017 2:52 pm
+1
I use this application a lot since I bought my RA+.
-James-
PostPosted: Sun May 14, 2017 6:28 pm
How does this work. Is it connected via ttl/usb to windows 10? I want to get a windows 2 in 1 or a full windows tablet and connect to it will this work?
PostPosted: Mon Jun 19, 2017 5:40 pm
troylong45 wrote:How does this work. Is it connected via ttl/usb to windows 10? I want to get a windows 2 in 1 or a full windows tablet and connect to it will this work?
I have it connected to my desktop (works on Windows 7 and 10) via USB/TTL. In the Settings, Notifications tab, you must check the "send parameters to Reef Angel Portal for online viewing." The SMS and email feature is very handy as well.
PostPosted: Mon Aug 28, 2017 5:48 am
I want to see my water level on the client. Searched here and found this:
Where do I upload this?
In the code?
ReefAngel.FeedingModePortsE[0] = Port1Bit | Port5Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port6Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit | Port5Bit;
ReefAngel.OverheatShutoffPorts = Port4Bit | Port7Bit;
ReefAngel.PHControl( Port2,818,820 );
ReefAngel.StandardLights( Port4,11,0,21,30 );
ReefAngel.Relay.DelayedOn( Port5,1 );
ReefAngel.WaterLevelATO( Port6,120,42,44 );
ReefAngel.StandardHeater( Port7,255,265 );
ReefAngel.Relay.DelayedOn( Box1_Port5,1 );
I don't see any option in the client settings to view water level expansion, just float switches.
Apologies if a stupid question, but am totally new to this
PostPosted: Mon Aug 28, 2017 7:16 am
The client is no longer being developer. It still works but I believe the water level sensor came after the client's last release. There is nothing to add to your code for the chart I posted.
PostPosted: Thu May 31, 2018 5:35 pm
Anyone else having issues with the checkbox for send parameters to Reef Angel Portal for online viewing? I keep trying to click it but nothing happens.
Previous
Return to Apps
