Cloud Wifi Attachment
PostPosted: Mon Jun 12, 2017 10:45 am
You mentioned it was working.
Is it not?
PostPosted: Fri Jun 16, 2017 8:07 am
No it's doing as in my second to last post on page 4. It stays green until I plug in the USB into a computer or wall outlet. Then it acts as if it resets itself so I can't serial monitor it. I had left it connected to just the reef angel since the 8th and it stayed connected until the 11th and had been solid green since then as I am out of the country and have a house sitter telling me the color of the light.
PostPosted: Fri Jun 16, 2017 5:47 pm
If you are getting this: "Attempting to connect to Network named:
Not connected..."
Your code is wrong. It doesn't have the SSID name.
PostPosted: Sun Jun 18, 2017 5:14 am
It does connect and I have verified data going to the U-App. The problem is after a time it goes to green light only, It's acting as if it locks up. My previous posts explain the steps I've taken after it locks up.
PostPosted: Sun Jun 18, 2017 3:01 pm
How far is it from router?
I wonder if it is loosing the connection.
PostPosted: Wed Jun 21, 2017 11:25 am
It is 10-15' and open air connection. No blockages. In the same room
PostPosted: Fri Jun 23, 2017 7:26 pm
I have been gone to Europe for 2 weeks and upon return it seems to unit is completely dead. Plugging in the USB or the cable to the reef angel. Should I email support?
PostPosted: Sun Jun 25, 2017 6:34 pm
Yes, send an email to info@reefangel.com
PostPosted: Sun Aug 13, 2017 10:46 pm
Kungpaoshizi wrote:Can we expect code uploads via the device someday?
I think that's one thing I would really like... Though I have gotten to the point where my reef tank setup is simple enough I don't need to change anything... lol
It seems jeelabs has released a couple months ago an alpha version of a firmware that emulates the stk500v2 that is required to program our microcontrollers :)
https://github.com/jeelabs/esp-link/releases
If someone is interested in investigating and checking if we could use it, let me know.
PostPosted: Mon Jun 11, 2018 3:47 pm
Am Getting an error trying to compile...I have the latest Dev library.
My_RA_Version_3_0.cpp: In function 'void loop()':
My_RA_Version_3_0:372: error: 'class ReefAngelClass' has no member named 'CloudPortal'
//Sketch Date May 13, 2018
//Version 3.0
#include <SunLocation.h>
#define NUMBERS_8x16
#define PI 3.141593
//#include <RA_PCA9685.h>
//#define I2CPWM_PCA9685      0x40
SunLocation sl;
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
////// Memory Locations used by all formulas
#define Mem_B_AcclDay  100
// Note - 100 represents the hard coded Memory location used for this variable
// not the value for the variable.
// This variable represents the current day in Acclimation Cycle. Set this value to the same
// number of days as your AcclDuration to begin the acclimation cycle or set it to 0 to use
// your normal dimming end% values.
#define Mem_B_AcclDuration  101 // Set this value to how many days you want your acclimation cycle to take.
#define Mem_B_SlopeStart  102 // Set this to your desired starting acclimation end%.
/////// Memory Locations used by Blue Formula
#define Mem_B_AcclStartEndBlue  105    // Acclimation starting Slope end%
#define Mem_B_SlopeEndBlue  106    // slope End%
////// Memory Locations used by White Formula
#define Mem_B_AcclStartEndWhite  110 // Acclimation starting Slope end%
#define Mem_B_SlopeEndWhite  111    // Slope End%
// Define Portal Variables
#define Var_AcclDay         0  // Days Left in Coral Acclimation
//#define Var_StormMode       1  // Lightning Storm Mode: 0=Slow (For Unresponsive LED Drivers: Meanwell ELN), 1=Fast, 2=Mega
//#define Var_Wmaker       2
//#define Var_Tide         3
//#define Var_TideMode     4
//#define Var_LogATO       5
//#define Var_WCVol        6
#define Var_weekday        7  //Day of the week: 0=Sunday, 1=Monday, 2=Tuesday, 3=Wednsday, 4=Thursday, 5=Friday, 6=Saturday
void DrawCustomMain() {  //5,14
  char buf[16];
  //byte acclDay = InternalMemory.read(Mem_B_AcclDay);
  ReefAngel.LCD.DrawLargeText(COLOR_BLACK, COLOR_WHITE, 10, 4, "Paradise Reef");
  // Temp and PH
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,10,65,"Temp:");
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,85, 65, "PH:");
  ConvertNumToString(buf, ReefAngel.Params.Temp[T2_PROBE], 10);
  ReefAngel.LCD.DrawText(T2TempColor, DefaultBGColor, 48, 73, buf);
  ReefAngel.LCD.DrawLargeText(T1TempColor, DefaultBGColor, 10, 75, buf, Num8x16);
  ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, 85, 75, buf, Num8x16);
  ConvertNumToString(buf, ReefAngel.Params.Temp[T3_PROBE], 10);
  ReefAngel.LCD.DrawText(T3TempColor, DefaultBGColor, 48, 82, buf);
  //ATO
  /*ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,15,40,"High",Font8x16);
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,85,40,"Low",Font8x16);
    ReefAngel.LCD.FillCircle(55,43,5,COLOR_GREEN);
  } else {
    ReefAngel.LCD.FillCircle(55,43,5,COLOR_RED);
    ReefAngel.LCD.FillCircle(70,43,5,COLOR_GREEN);
  } else {
    ReefAngel.LCD.FillCircle(70,43,5,COLOR_RED);
  //Salinity
  strcat(text,"  ");
  ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,15,93,"Salinity:");
  ReefAngel.LCD.DrawText(COLOR_NAVY,DefaultBGColor,75,93,text);
  //Sunrise/Sunset Times
  //ReefAngel.LCD.DrawText(0,255,5,52,"Rise:");
  //ReefAngel.LCD.DrawText(0,255,38,52,(sl.GetRiseHour()));
  //ReefAngel.LCD.DrawText(0,255,43,52,":");
  //ReefAngel.LCD.DrawText(0,255,48,52,(sl.GetRiseMinute()));
  //ReefAngel.LCD.DrawText(0,255,65,52,"Set:");
  //ReefAngel.LCD.DrawText(0,255,88,52,(sl.GetSetHour()));
  //ReefAngel.LCD.DrawText(0,255,100,52,":");
  //ReefAngel.LCD.DrawText(0,255,105,52,(sl.GetSetMinute()));
  //Moon Phase
  //ReefAngel.LCD.DrawText(0,255,5,72,"Moon:");
  //ReefAngel.LCD.DrawText(0,255,35,72,MoonPhaseLabel());
  // Display Acclimation timer
  //ReefAngel.LCD.DrawText(0,255,5,82,"Acclimation Day:");
  //ReefAngel.LCD.DrawText(0,255,105,82,acclDay);
  // Display LED %
  //ReefAngel.LCD.DrawText(0,255,12,92, "CW:");
  //ReefAngel.LCD.DrawText(197,255,32,92, ReefAngel.PWM.GetDaylightValue());
  //ReefAngel.LCD.DrawText(0,255,72,92, "RB:");
  //ReefAngel.LCD.DrawText(3,255,92,92, ReefAngel.PWM.GetActinicValue());
  // Display Relays
  ReefAngel.LCD.DrawOutletBox(12, 102, TempRelay);
    ReefAngel.LCD.DrawGraph(5, 12);
/*void SeasonalTemps ()
  static int heatArray[][2] = { {792,796},// default in case of error in month=0 (June)
                    {770,774},//January (winter)
                    {774,778},//February (winter)
                    {775,779},//March (early spring)
                    {779,783},//April (spring)
                    {785,789},//May (spring)
                    {792,796},//June (early summer)
                    {799,803},//July (summer)
                    {806,810},//August (summer)
                    {796,800},//September (early fall)
                    {787,791},//October (fall)
                    {780,784},//November (fall)
                    {775,779} };//December (early winter)
  ReefAngel.StandardHeater( Port2,heatArray[month()][0],heatArray[month()][1]);
    //ReefAngel.Use2014Screen();  // Let's use 2014 Screen
    ReefAngel.AddSalinityExpansion();
    // Default Salinity compensation
    ReefAngel.Salinity.SetCompensation(0);
    ReefAngel.FeedingModePorts = Port3Bit| Port5Bit | Port6Bit ;
    ReefAngel.WaterChangePorts = Port2Bit | Port3Bit | Port5Bit | Port6Bit;
    ReefAngel.LightsOnPorts = Port7Bit | Port8Bit;
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port5 );
    ReefAngel.Relay.On( Port7 );
  //sl.Init(-21.285833, 150.999722); // In decimal numbers (i.e. -18.285833, 147.699722)
  //sl.SetOffset(11,0,11,0); // rise_hour, rise_seconds, set_hour, set_seconds
    sl.Init(38.8447,-104.8433); // Colorado Springs,CO In decimal numbers (i.e. -18.285833, 147.699722)
    sl.SetOffset(-6,0,-6,0); // rise_hour, rise_seconds, set_hour, set_seconds
  randomSeed(now()/SECS_PER_DAY);
  //if (InternalMemory.read(Mem_B_ResetMemory))
    //init_memory();
        //Temp Code for Fuge Light
    //ReefAngel.StandardLights( Port5,sl.GetSetHour(),sl.GetSetMinute(),sl.GetRiseHour(),sl.GetRiseMinute() );
    //ReefAngel.StandardLights( Port7,sl.GetSetHour(),sl.GetSetMinute(),sl.GetRiseHour(),sl.GetRiseMinute() );
    // 15min Delay on Skimmer coming from Feeding oe Waterchange Modes
    ReefAngel.Relay.DelayedOn(Port3, 10);
    // Custom Variable for Portal
    ReefAngel.CustomVar[Var_weekday]=weekday();
    //Heater
    //SeasonalTemps();
    // Jebao Code
    pinMode(lowATOPin,OUTPUT);
    analogWrite(lowATOPin,ReefCrestMode(50,20,true)*2.55);
    ReefAngel.DCPump.LowATOChannel = AntiSync ; // Jebo connected to AtoPINLow
    pinMode(highATOPin,OUTPUT);
    analogWrite(highATOPin,ReefCrestMode(50,20,true)*2.55);
    ReefAngel.DCPump.HighATOChannel = AntiSync ; // Jebo connected to AtoPINLow
    static int rmode;
    byte modes[] = { Lagoon, ReefCrest, TidalSwell, Sine, Gyre, NutrientTransport, Else };
    changeMode=true;
    static unsigned long feeding;
    if (now()-feeding<900) {
      // First 15 minutes after feeding mode stops. Smart_NTM
    } else if (now()-feeding<2250) { // 15 minutes plus 1 hour
      // Continue NTM for the next 60 minutes (75 minutes total)
    } else if (now()%SECS_PER_DAY<23400 || now()%SECS_PER_DAY>=72000) { // 6:30am / 8:00pm
      // Night mode (go to 30%)
      ReefAngel.DCPump.Speed=32;
      //ReefAngel.DCPump.SetMode(Constant,31,45,30);
      if (modes[rmode]==Else) {
        ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),25,true );    // ElseMode on sync mode, Portal Speed Setting +/- 25%
      } else {
        ReefAngel.DCPump.Mode=modes[rmode];  // Put the mode to the random mode :)
    } else {
////////// Variables used for all channels
// What day in the acclimation cycle it is
  byte acclDuration = InternalMemory.read(Mem_B_AcclDuration);
// Acclimation Duration in days
  byte startPercent = InternalMemory.read(Mem_B_SlopeStart);
// Normal start% being used by all 3 channels
////////// Blue Channel Variables
  byte acclStartEndBlue = InternalMemory.read(Mem_B_AcclStartEndBlue);
// Starting End% for Acclimation cycle
  float acclendPercentBlue = InternalMemory.read(Mem_B_SlopeEndBlue);
// Your target Blue end% once acclimation is complete
////////// Blue Channel Formula
  float acclPercentPerDayBlue = (acclendPercentBlue - acclStartEndBlue) / acclDuration;
// How much your Blue end% rises per acclimation day
  float acclFactorBlue = acclDay * acclPercentPerDayBlue;
// endPercentBlue will be offset by this much. If acclDay = 0 then this value will be 0
  byte endPercentBlue = acclendPercentBlue - acclFactorBlue;
// Your final Blue end% for the day
////////// White Channel Variables
  byte acclStartEndWhite = InternalMemory.read(Mem_B_AcclStartEndWhite);
  float acclEndPercentWhite = InternalMemory.read(Mem_B_SlopeEndWhite);
// Your target White end% once acclimation is complete
////////// White Channel Formula
  float acclPercentPerDayWhite= (acclEndPercentWhite - acclStartEndWhite) / acclDuration;
// How much your White end% rises per acclimation day
  float acclFactorWhite = acclDay * acclPercentPerDayWhite;
// endPercentWhite will be offset by this much. If acclDay = 0 then this value will be 0
  byte endPercentWhite = acclEndPercentWhite - acclFactorWhite;
ReefAngel.CustomVar[Var_AcclDay]=acclDay;
// At the end of the day, we need to decrement the acclimation counter.
  static boolean acclCounterReady=false; // We need a boolean so we only do this once per day
  if (now()%SECS_PER_DAY!=0) acclCounterReady=true; // If it's not midnight we'll get the boolean ready
  if (now()%SECS_PER_DAY==0 && acclCounterReady && acclDay>0) { // It's midnight, our bool is true and acclDay is more than 0
    acclDay--; // Reduce the counter
    acclCounterReady=false; // Reset the boolean flag
    InternalMemory.write(Mem_B_AcclDay,acclDay); // Update memory
    // handle updating sunrise and sunset values
    sl.CheckAndUpdate();
    //ReefAngel.Portal( "89delta","collin1123" );
    //ReefAngel.DDNS( "bc29" ); // Your DDNS is 89delta-bc29.myreefangel.com
    ReefAngel.CloudPortal();
  ActinicPWMValue=PWMSlope(sl.GetRiseHour(),sl.GetRiseMinute(),sl.GetSetHour(),sl.GetSetMinute(),startPercent,endPercentBlue,120,(MoonPhase()/3));
  DaylightPWMValue=PWMSlope(sl.GetRiseHour(),sl.GetRiseMinute(),sl.GetSetHour(),sl.GetSetMinute(),startPercent,endPercentWhite,120,DaylightPWMValue);
  CheckCloud();
// RA_STRING1=U2FsdGVkX19/CQXYxFHutorfRImY8TNubevs+8+6Sjw=
// RA_STRING2=U2FsdGVkX1+7EBoxpKZdEtYXEBfHD+fIe5qrAeDKTa8=
// RA_STRING3=Gundel
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Cloud_Chance_per_Day 50
  // Minimum number of minutes for cloud duration.  Don't use max duration of less than 6
#define Min_Cloud_Duration 6
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 10
#define Start_Cloud_After NumMins(7,30)
#define End_Cloud_Before NumMins(20,00)
#define Lightning_Change_per_Cloud 55
  // Add Random Lightning modes
#define Slow 0    // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 1    // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 2    // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 3   // Like Mega, but with more lightning
  // Example:  { Slow, Fast, Mega, Mega2 } to randomize all four modes.
  // { Mega2 } for just Mega2.  { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
byte LightningModes[] = { Fast, Mega, Mega2 };
    //ReefAngel.CustomVar[Var_StormMode]=lightningMode;
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
  static byte lightningMode=0;
  static time_t DelayCounter=millis();    // Variable for lightning timing.
  static int DelayTime=random(1000);      // Variable for lightning timimg.
#ifdef forcecloudcalculation
    if (cloudchance==255)
#else
#endif
      randomSeed(millis());    // Seed the random number generator
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    //is it time for cloud yet?
      if (chooseLightning) { lightningMode=LightningModes[random(100)%sizeof(LightningModes)]; chooseLightning=false; }
        switch (lightningMode) {
        case Mega:
        // Lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
        int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
        for (int i=0; i<a; i++)
          analogWrite(daylightPWMPin,random(DaylightPWMValue*2.55,255));    // Flash on
          int randy=random(20,80);    // Random number for a delay
          if (randy>71) randy=((randy-70)/2)*100;    // Small chance of a longer delay
          delay(randy);                // Wait from 20 to 69 ms, or 100-400 ms
          analogWrite(daylightPWMPin,DaylightPWMValue*2.55);      // Flash off
          delay(random(30,50));                // Wait from 30 to 49 ms
          wdt_reset();
        DelayCounter=millis();    // If we just had a round of flashes, then lets put in a longer delay
        DelayTime=random(1000);   // of up to a second for dramatic effect before we do another round.
      break;
       case Mega2:
        // Higher lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
      if (lightningchance && random(ReversePWMSlope(cloudstart,cloudstart+cloudduration,100,0,180))<2 && (millis()-DelayCounter)>DelayTime)
          wdt_reset();
      break;
        case Fast:
          wdt_reset();
      break;
        case Slow:
        // Slow lightning for 5 seconds in the middle of the cloud.  Suitable for slower ELN style drivers
        else lightningstatus=0;
        if (lightningstatus)
          DaylightPWMValue=100;
          DaylightPWMValue=0;
        delay(1);
        break;
        default:
        break;
    } else {
      cloudindex++;
      if (cloudindex < numclouds)
    //ReefAngel.LCD.Clear(255,0,62,132,132);
  //ReefAngel.LCD.DrawText(0,255,5,62,"C");
  //ReefAngel.LCD.DrawText(0,255,11,62,"00:00");
  //ReefAngel.LCD.DrawText(0,255,45,62,"L");
  //ReefAngel.LCD.DrawText(0,255,51,62,"00:00");
      int x=0;
      //ReefAngel.LCD.DrawText(0,255,x,62,(cloudstart/60));
      //ReefAngel.LCD.DrawText(0,255,x,62,(cloudstart%60));
    //ReefAngel.LCD.DrawText(0,255,90,62,cloudduration);
    if (lightningchance)
      int x=0;
      //ReefAngel.LCD.DrawText(0,255,x,62,((cloudstart+(cloudduration/2))/60));
      //ReefAngel.LCD.DrawText(0,255,x,62,((cloudstart+(cloudduration/2))%60));
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
PreviousNext
Return to Addons
