So I've been toying around with the RA Web Wizard and I noticed a few possible errors, also there was a line of code that didn't work with the traditional coding and I was wondering what it could be.
Web Wizard error?
- When I set it to internal memory for the lighting portion it still generates the following:
ReefAngel.StandardLights( Port1,23,55,3,0 );
shouldn't it generate
Also I did the following if then and when I pasted it into the traditional INO code it said it was an Error.
If Feeding mode is active to put the Jebao into Nutrient Transport mode.
- It generated a code that said isfeeding
The traditional INO said it wasn't valid.
RA Web Wizard and Traditional Wizard ino coding
GugsJr
Re: RA Web Wizard and Traditional Wizard ino coding
Different libraries.
It won't work.
You have to compile on webwizard and upload on webwizard.
I'll check on the internal memory bug.
It won't work.
I can't seem to be able to replicate the internal memory bug you are reporting.
