Problems uploading code
PostPosted: Fri Jun 30, 2017 1:21 pm
pleas hellp:
Simple Menu
Dvejetainis projekto dydis: 23 254 baitų (iš 258 048 leistinų)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM20 -b115200 -D -Uflash:w:C:\Users\J5C03~1.JOL\AppData\Local\Temp\build6773403092298326202.tmp\sketch_jun30a.cpp.hex:i
Copyright (c) 2000-2005 Brian Dean,
Using Port : \\.\COM20
Using Programmer : stk500v2
Overriding Baud Rate : 115200
avrdude: Recv:
avrdude done. Thank you.
PostPosted: Sun Jul 02, 2017 6:07 pm
I would verify that you have the correct COM port selected. Your output shows that you have COM20 selected. That number seems high.
Also, verify that you have the correct Reef Angel controller selected. Reef Angel vs Reef Angel Plus.
PostPosted: Tue Jul 04, 2017 11:17 am
I found it bad, the cable is bad
Return to For New Members
