Is there a point where a user stops using RA-Gen? Is seems to me that once we start inserting custom snippets of code into our sketches we can no longer use the RA Gen. Is this correct?
Thx
RA-GEN vs Handwritten code
rossbryant1956
Re: RA-GEN vs Handwritten code
Pretty much.
The RAGen will only give you a base skeleton.
If you start adding stuff to your code, you no longer need to use RAGen.
