Inverted pH control
jcjrogers
Inverted pH control
I've split my RO reservoir line to run to my kalk stirrer and directly to the sump. I've also installed a solenoid on the line running to the sump. When pH is "high" I want to turn on the solenoid, allowing RO to flow directly to the sump. When pH is "low", I want to turn the solenoid off forcing all water through the kalk stirrer. I'm using internal memory but if you set to turn on at the "high" and off at the "low", it doesn't work. How can I make work?
jcjrogers
Re: Inverted pH control
Perfect. Thanks!rimai wrote:inverted ph control is co2 control
