I hope you are all well!! I am needing some help with adding more ATO pumps to my Reef Angel (RA) system I currently have ATO1 (StandardAto) operating fine on relay box port 1 with float switches connected to the high and low ATO float switches input ports on the RA controller.
I am needing to sort out ATO2 which I want on relay box port 2 with float switches connected to channnel 0 and channel 1 on the i/o expansion module.
I may also add more ATO's in the future so can anyone please assist with the code.
@rimai
Code is as follows:
byte x,y;
byte bkcolor;
ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params);
y=10;
x=15;
for (int a=0;a<6;a++)
if(ReefAngel._IO.GetChannel(a)) bkcolor=COLOR_RED;
else bkcolor=COLOR_GREEN;
if (a>2) x=75;
if (a==3) y=10;
ReefAngel.LCD.Clear(bkcolor, x, y-3, x+40,y-1);
ReefAngel.LCD.Clear(bkcolor, x, y+8, x+40,y+10);
ReefAngel.LCD.Clear(bkcolor, x, y, x+3,y+8);
ReefAngel.LCD.Clear(bkcolor, x+37, y, x+40,y+8);
ReefAngel.LCD.DrawText(COLOR_WHITE, bkcolor, x+3, y, "Input");
ReefAngel.LCD.DrawText(COLOR_WHITE, bkcolor, x+32, y, a);
y+=15;
For more information about custom main screen (RA forum URL removed)
// Define Relay Ports By Name
#define ATO1 1
#define ATO2 2 *This is the one i must sort out.
#define Skimmer 3
#define Daylights 4
#define Flowpumps1 5
#define Flowpumps2 6
#define Heaters 7
#define Return 8
ReefAngel.Init(); // Initialize Controller
ReefAngel.AddDateTimeMenu();
ReefAngel.AddStandardMenu();
ReefAngel.SetTemperatureUnit(Celsius); // set Temperature to Celsius
ReefAngel.FeedingModePorts = Port5Bit | Port6Bit; // Turn off Ports 5 and 6 when Feeding Mode is activated
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit; // Turn off Ports 1, 2, 3, 5, 6, 7 and 8 when Water Change Mode is activated
ReefAngel.OverheatShutoffPorts = Port4Bit | Port7Bit; // Turn off Ports 4 and 7 when Overheat Occurs
ReefAngel.LightsOnPorts = Port4Bit; // Turn on/off Ports 4 when Turn Lights On/Off is activated
ReefAngel.OverheatProbe = T1_PROBE | T2_PROBE | T3_PROBE; // Use Temperature probe 1, 2 and 3 to check for overheat
ReefAngel.TempProbe = T1_PROBE | T2_PROBE | T3_PROBE; // Use Temperature probe 1, 2 and 3 to check temperature
// Always on
ReefAngel.Relay.On(Return);
ReefAngel.Relay.On(Skimmer);
ReefAngel.Relay.On(Flowpumps1);
ReefAngel.Relay.On(Flowpumps2);
ReefAngel.StandardATO(ATO1); // Standard ATO
ReefAngel.StandardLights(Daylights); // Daylight Lights
ReefAngel.StandardHeater(Heaters); // Heater
ReefAngel.PWM.StandardDaylight(); // Dimming for Daylight Channel
ReefAngel.PWM.StandardActinic(30); // Dimming for Actinic Channel
ReefAngel.ShowInterface(); // Display everything on the LCD screen
If i can see the ReefAngel.StandardATO code as it is written in the RA memory then i may be able to use that as the only difference will be that the input ports for the float switches will be on the i/o expansion module and not the RA controller as with ATO1.
