WIFI Cloud and WIFI Attachment on 2 RA plusses
Re: WIFI Cloud and WIFI Attachment on 2 RA plusses
Not sure I follow.
Let's try using your USB-TTL cable instead of the micro usb on the side.
Connect it to the cloud wifi attachment and open serial monitor.
Press and hold the debug then press and release the reset master then release debug.
Do you get anything on monitor this way?
Make sure you are pressing the correct button. It is not the AP Reset on the side of the unit. It is the reset master on the top right corner.
If that doesn't produce anything, you may need to post a video.
ecamFT
G¬yYPmH@HlFfyÈ&wCP@æýyÈuiJÕTÄVé9ÈÈHP@g¡`Fo%JÔTÿZTå¡TEÔg{^pHTEYÖ!\-Z`H`HQü^Gþ
Current version: 1.0.0
mounted file system
reading config file
opened config file
{"mqtt_username":"EcamFT","mqtt_password":"K*******"}
parsed json
*WM: Adding parameter
*WM: Cloud Username
*WM: Cloud Password
*WM:
*WM: AutoConnect
*WM: Connecting as wifi client...
*WM: Using last saved values, should be faster
*WM: Connection result:
*WM: 3
*WM: IP Address:
*WM: 192.168.1.229
username: EcamFT
password: K*********
IP address: 192.168.1.229
Connecting to cloud server...
Failed, rc=5 try again in 30 seconds
ecamFT
i took out my password..... but it was correct
and the failure log keeps repeating
it failed to connected t to cloud server.
It may be because of the username if you are positive the password is correct.
Try changing from EcamFT to ecamFT.
ecamFT
so i should do a factory reset? on the cloud wifi? or is there another way to change the user name
ecamFT
Success!!!!!!!!!!!!!!!!!!!! this whole ordeal because of an uppercase E..... SMH
im sooo sorry Roberto.... thank you for the patience and awesome customer service
Cool!!!
I'll update the manual to state that both username and password need to be case sensitive.
How do you like the Uapp and the whole cloud connection?
Isn't it really nice to see data streaming through?
ecamFT
yes it is.... i just grabbed an old ipad laying around... i have a huge screen controller now
Thanks for all the help
ecamFT
i have a few code questions if you are up for it... Like labels now in the UAPP
also need to code in a swabbie (run every 6 hrs for 20 seconds)
and also still need to do some coding on the skimmer (I have a question out on the how do i code section)
ecamFT
something im noticing is the data is streaming great... but the relay commands keep timing out... the light is still flashing CYAN... and numbers match controller..... but relay commands kepp timing out
The labels you set in the portal. Need to do that with your new account.
I've seen the issue with relays timing out as well btw. But it works fine.
ecamFT
lnevo wrote:The labels you set in the portal. Need to do that with your new account.
looks like we are back to the first problem... the WIFI unit is communicating to ecam and ecamFT on the portal.
Still not sure how...
So since I have it disconnected its showing unreachable address. and when I update in portal.. nothing happens
You are looking at something else that we are not.
http://forum.reefangel.com/status/chart ... &filter=t1
Last time ecam connected to the portal was Thursday.
Oh, I think I know what you are seeing.
You must have the port forwarding 2000 sent to your cloud WiFi IP address and not the standard wifi
The cloud WiFi is still able to respond to requests on port 2000 just like the old one.
ecamFT
How should I fix this ?
I never did any port forwarding on cloud ?
Only thing being forwarded the original wifi and they both have Seperate ip.
up
up
Check your router and see where port 2000 is being forward to.
I bet it is to the ip address of cloud wifi if you are saying that you are seeing data from ecamFT.
An easy way to check is to browse to http://yourexternalipaddress:2000/r99
And see what it comes up with.
Change yourexternalipaddress to your external ip address shown in the portal.
- Contact:
Wow. that's crazy. About time you guys got it figured out!ecamFT wrote:Success!!!!!!!!!!!!!!!!!!!! this whole ordeal because of an uppercase E..... SMH
