Unreachable Address in portal
Related to the Portal
PostPosted: Wed Aug 30, 2017 1:22 pm
It is all done in the router configuration.
Each router has its own way.
PostPosted: Wed Aug 30, 2017 1:56 pm
Again, apologies for my ignorence.
I understand that, but is the 192.xxx.xx.x:2000 not the ip address assigned to my RA wifi attachment by my router?
Thats the address I got in the wifi attachment setup process, so do i have to connect my wifi attachment to my laptop again?
PostPosted: Wed Aug 30, 2017 2:05 pm
I don't know.
The only way to find out for sure is to login to your router and check which one the router really gave to your wifi attachment if this ip address is not working anymore.
PostPosted: Wed Aug 30, 2017 2:49 pm
Okay, I am logged in to my router, DHCP server is on, would that equate to a dhcp reservation?
PostPosted: Wed Aug 30, 2017 3:11 pm
I see my DHCP IP range is start 192.168.0.1 and END 192.168.0.200, but i also dont know where to see what ip address has been assigned to my wifi attachment
PostPosted: Wed Aug 30, 2017 3:19 pm
They should be a list of attached devices where each device has an ip address.
In my NAT settings, I must name a source port, a destination IP and a destination port, what do i put into each of thise?
PostPosted: Wed Aug 30, 2017 3:21 pm
rimai wrote:They should be a list of attached devices where each device has an ip address.
Found it, IP address is the same as was assigned yesterday
PostPosted: Wed Aug 30, 2017 3:30 pm
There you go.
Each router has its own way of naming things.
Your router calls it connected devices.
I can't possibly know what all routers are gonna call everything and how to set it up. Sorry.
We use port 2000, so source and destination port is the same 2000.The destination ip address is the exact thing that you are trying to find out: The wifi attachment ip address.
Another user wrote a little tutorial for his particular router that may help you.
viewtopic.php?f=14&t=1190
You can also search in the internet on how to do it in your particular router or call your internet provider/router manufacturer.
There is also a software that automates simple key pushes that I've heard works pretty good:
http://www.simpleportforwarding.com/
PostPosted: Wed Aug 30, 2017 3:44 pm
Thank you for all your assistance, I know it must be annoying to deal with us less clever folk...I seem to be getting somewhere. The portal seems to be refreshing on a regular basis. I have entered the ip address into my iphone app but still no luck there, but it will have to wait until I rob a bank and buy the cloud wifi attachment.
PreviousNext
Return to Portal
Users browsing this forum: Google [Bot] and 0 guests
