Float Switch Connector
rrodriguess
Post by rrodriguess »
Hi there
Does anybory knows what is the connector's name in the end of the float switch? The white one used to connect to RA?
Best regards
Rafa
Re: Float Switch Connector
Look for dimming port lead wire on the webstore.
rrodriguess
Tks Roberto
Is it a JST XHP-2 connector? Maybe I can find it here in Brazil
No. they are not.
They are pretty standard and you should be able to find them in the local electronic store.
