Hi
Can someone help me program the dimming ports on the expansion relax box to control wave makers instead?
Im pretty crap at arduino but can edit and compile code just not add anything meaningful to it.
Currently I have my lights dimming on the main box but I have no idea how to add any function to the 2nd box if its not in the wizard.
Any help greatly appreciated.
Thank you
Adam
Relay box 1 - control wavemakers
- Contact:
Re: Relay box 1 - control wavemakers
I don't think that the dimming ports on the expansion relay boxes are able to be used. if you want/need additional dimming ports, then you will need to get the dimming expansion module which has 6 dimming ports.
if I'm wrong, I'm sure others will chime in to correct me.
Stomp
So you cant program the 2 dimming ports on the 2nd box to do anything different to the same box?
Bump can anyone help please
