Seasonal Temperatures
Ask in here.
PostPosted: Thu Oct 12, 2017 5:08 pm
void SeasonalTemps ()
  static int heatArray[][2] = { {792,796},// default in case of error in month=0 (June)
                    {770,774},//January (winter)
                    {774,778},//February (winter)
                    {775,779},//March (early spring)
                    {779,783},//April (spring)
                    {785,789},//May (spring)
                    {792,796},//June (early summer)
                    {799,803},//July (summer)
                    {806,810},//August (summer)
                    {796,800},//September (early fall)
                    {787,791},//October (fall)
                    {780,784},//November (fall)
                    {775,779} };//December (early winter)
  ReefAngel.StandardHeater( Port2,heatArray[month()][0],heatArray[month()][1]);
 }//end seasonalTemps
hi, saw this and would love to add this to my ino but am worried I won't implement it properly.
is there anything I need to change or remove from my current code?
    InternalMemory.LCDID_write(0); //this line was added when i got a replacement RA+ board
    ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit;
    ReefAngel.Relay.On( Port4 );
    ReefAngel.DayLights( Port2 );
    ReefAngel.Relay.DelayedOn(Port5 );
    ReefAngel.DosingPumpRepeat1( Port7 );
    ReefAngel.DosingPumpRepeat2( Port8 );
    ReefAngel.DCPump.LowATOChannel = Sync; // WP40
    ReefAngel.DCPump.HighATOChannel = AntiSync; // SW-8
    ReefAngel.DCPump.AntiSyncOffset = 125;
    // Wavemaker
    if ( ((hour() >= 2) && (hour() < 8)) || ((hour() >= 15) && (hour() < 19)) ) // off from 2am-8am & 3pm-7pm
        ReefAngel.Relay.Off(Port6);
        ReefAngel.WavemakerRandom( Port6, 30, 150 ); // random between 30 and 150 seconds
    // DC pumps....................................
    static int rmode;
    byte modes[] = { ReefCrest, Lagoon, TidalSwell, ShortPulse, Sine, Else, Gyre, NutrientTransport };
    if (now()%1800==0 || changeMode==true)  // Change every 30 mins (1800seconds) or controller reboot
    rmode=random(100)%sizeof(modes); // Change the mode by picking from our array
    changeMode=false;
    static unsigned long feeding;
    // Continue NutrientTranspot Mode for 30 minutes after feeding
    if (now()-feeding<1800)
    ReefAngel.DCPump.Mode=ReefCrest;
    ReefAngel.DCPump.Speed=75;
    // Night/Quiet mode
      else if (hour()>=2 && hour()<8 ) // 2am to 8am
    ReefAngel.DCPump.SetMode( Gyre,40,10 );
      else if (hour()>=15 && hour()<19) // 3pm and 7pm
    ReefAngel.DCPump.SetMode( ShortPulse,40,30 );
    //Storm mode
    else if (hour()>=1 && hour()<2) // 1am and 2am
    ReefAngel.DCPump.SetMode( Else,70,15 );
      else if (hour()>=11 && hour()<12) // 11am and 12pm
    ReefAngel.DCPump.SetMode( ReefCrest,80,15 );
    else if (InternalMemory.DCPumpMode_read()==11)
    } else {
    ReefAngel.Portal( "" );
    ReefAngel.DDNS( "" ); // Your DDNS is
PostPosted: Thu Oct 12, 2017 7:13 pm
you will want to change the port in the seasonaltemps function to use port3, like your code.
then you will want to remove /comment out the standardheater function call from your loop and instead just call SeasonalTemps(); function.
it shouldn't affect anything else. the only other thing to check on is your overheat temperature value and make sure it is higher than the temperatures listed in the seasonaltemps function.
PostPosted: Fri Oct 13, 2017 4:13 am
thats awesome, thanks Curt.
is there a way to do something similar with my lighting? i.e.. longer days when it's warmer and shorter days when the water is cooler.
PostPosted: Fri Oct 13, 2017 5:50 pm
in theory, you certainly could. if you did it this way, you would have to hard code the light schedule instead of using the memory (although you could do memory, it would just be more complicated).
do you have an idea of what what the light schedule would be?
would there be a ramp up or ramp down for leds or is it just an outlet turning on/off?
PostPosted: Fri Oct 13, 2017 6:40 pm
I don't want anything complicated so hard code would be just fine. I currently ramp my white leds from 0 to 65 on slope over 90 mins and my actinics from 0 to 80 over 90 mins as well.
how would I go about hard coding this?
PostPosted: Fri Oct 13, 2017 8:02 pm
to do it, you will need to create an array of the parameters that would be used. if the slope ranges always stay the same, then that will simply things. I'm assuming that they will and you will be adjusting the overall total daylight.
so, what I would start with is creating an array of start/stop times for the daylight, like the low and high temps.
{8,0,16,0} - on at 8am and off at 1600 (4p). so on hour, on minute, off hour, off minute.
make an array for all the months of the year.
once you have that, then we need a function that calls the sloping of the lights with the hard coded values based on the month. like the temp calls the hard coded standardheater function with values.
that's a start for you.
PostPosted: Sat Oct 14, 2017 5:43 am
Thanks for your help Curt
so something like this for daylight on port 2?
void SeasonalDaylight ()
  static int heatArray[][2] = { {13,0,22,0},// default in case of error in month=0 (May)
                    {15,0,22,0},//January (winter)
                    {14,30,22,0},//February (winter)
                    {14,0,22,0},//March (early spring)
                    {13,30,22,0},//April (spring)
                    {13,0,22,0},//May (spring)
                    {12,30,22,0},//June (early summer)
                    {12,0,22,0},//July (summer)
                    {12,30,22,0},//August (summer)
                    {13,0,22,0},//September (early fall)
                    {13,30,22,0},//October (fall)
                    {14,0,22,0},//November (fall)
                    {14,30,22,0} };//December (early winter)
  ReefAngel.DayLights( Port2,heatArray[month()][0],heatArray[month()][1]);
 }//end SeasonalDaylight
and actinics on port 1
void SeasonalActiniclight ()
  static int heatArray[][2] = { {12,30,22,30},// default in case of error in month=0 (May)
                    {14,30,22,30},//January (winter)
                    {14,0,22,30},//February (winter)
                    {13,30,22,30},//March (early spring)
                    {13,0,22,30},//April (spring)
                    {12,30,22,30},//May (spring)
                    {12,0,22,30},//June (early summer)
                    {11,30,22,30},//July (summer)
                    {12,0,22,30},//August (summer)
                    {12,30,22,30},//September (early fall)
                    {13,0,22,30},//October (fall)
                    {13,30,22,30},//November (fall)
                    {14,0,22,30} };//December (early winter)
  ReefAngel.ActinicLights( Port1,heatArray[month()][0],heatArray[month()][1]);
 }//end SeasonalActinics
thats my best guess at coding :D not sure how to ramp lights up via slope or adjust the intensity by month/season?
thanks
PostPosted: Sat Oct 14, 2017 9:11 am
close, but you need some tweaking. give me a few hours to tweak it some for you and I'll post some code for you to test
PostPosted: Sat Oct 14, 2017 10:02 am
Do you have 2 sets of lights? Looking at your code, you toggle Port 1 for your Actinic lights and Port 2 for your Daylight Lights. Plus, you also have the PWM channels using the ActinicPWMSlope and DaylightPWMSlope.
I'm assuming that you have the power supplies for your LEDs plugged into the Relay Box and you just turn the power supplies off when you want the LEDs to be off in addition to dimming them down.
Is this correct?
PostPosted: Sat Oct 14, 2017 10:26 am
I have one set of lights. I use pwm channels for the same lights because they dim down low but won't shut down completely unless they are plugged into the relay box. I would like to use those ports for something else, is there a way to shut them down with the pwm alone?
Next
Return to How do I code ...
