void SeasonalTemps ()
static int heatArray[][2] = { {792,796},// default in case of error in month=0 (June)
{770,774},//January (winter)
{774,778},//February (winter)
{775,779},//March (early spring)
{779,783},//April (spring)
{785,789},//May (spring)
{792,796},//June (early summer)
{799,803},//July (summer)
{806,810},//August (summer)
{796,800},//September (early fall)
{787,791},//October (fall)
{780,784},//November (fall)
{775,779} };//December (early winter)
ReefAngel.StandardHeater( Port2,heatArray[month()][0],heatArray[month()][1]);
}//end seasonalTemps
is there anything I need to change or remove from my current code?
InternalMemory.LCDID_write(0); //this line was added when i got a replacement RA+ board
ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.DayLights( Port2 );
ReefAngel.Relay.DelayedOn(Port5 );
ReefAngel.DosingPumpRepeat1( Port7 );
ReefAngel.DosingPumpRepeat2( Port8 );
ReefAngel.DCPump.LowATOChannel = Sync; // WP40
ReefAngel.DCPump.HighATOChannel = AntiSync; // SW-8
ReefAngel.DCPump.AntiSyncOffset = 125;
// Wavemaker
if ( ((hour() >= 2) && (hour() < 8)) || ((hour() >= 15) && (hour() < 19)) ) // off from 2am-8am & 3pm-7pm
ReefAngel.Relay.Off(Port6);
ReefAngel.WavemakerRandom( Port6, 30, 150 ); // random between 30 and 150 seconds
// DC pumps....................................
static int rmode;
byte modes[] = { ReefCrest, Lagoon, TidalSwell, ShortPulse, Sine, Else, Gyre, NutrientTransport };
if (now()%1800==0 || changeMode==true) // Change every 30 mins (1800seconds) or controller reboot
rmode=random(100)%sizeof(modes); // Change the mode by picking from our array
changeMode=false;
static unsigned long feeding;
// Continue NutrientTranspot Mode for 30 minutes after feeding
if (now()-feeding<1800)
ReefAngel.DCPump.Mode=ReefCrest;
ReefAngel.DCPump.Speed=75;
// Night/Quiet mode
else if (hour()>=2 && hour()<8 ) // 2am to 8am
ReefAngel.DCPump.SetMode( Gyre,40,10 );
else if (hour()>=15 && hour()<19) // 3pm and 7pm
ReefAngel.DCPump.SetMode( ShortPulse,40,30 );
//Storm mode
else if (hour()>=1 && hour()<2) // 1am and 2am
ReefAngel.DCPump.SetMode( Else,70,15 );
else if (hour()>=11 && hour()<12) // 11am and 12pm
ReefAngel.DCPump.SetMode( ReefCrest,80,15 );
else if (InternalMemory.DCPumpMode_read()==11)
ReefAngel.DCPump.Mode=modes[rmode]; // Put the mode to the random mode :)
} else {
ReefAngel.Portal( "" );
ReefAngel.DDNS( "" ); // Your DDNS is
