controllable return pumps?
anderzon_
which return pumps can be controlled with reefangel. Have searched a little but find nothing special
Re: controllable return pumps?
Not many anymore. There's a thread recently where someone found...I can't remember the name now. I'll find him...
anderzon_
ok, why not anymore? I wanna do like this in the video https://www.youtube.com/watch?v=r15TTX-KHZw
Sorry, I posted to wrong thread:
http://forum.reefangel.com/viewtopic.php?t=6096
The issue is that Jaebo is now using a different protocol, PWM is no longer sufficient to control those pumps.
- Loose
Gosh, I wish I'd seen this post yesterday as I just ordered the Jebao cable in hopes I could control my DCP-10000 return pump.
anderzon_
maybe speed wave and waveline are controllable. I havent order a return pump yet because I wanna have a controllable
Look for ones now advertising apex control
anderzon_
So jebao / jecod dont uses pwm or analog? Its possible to controll the jebao wp streampump as far i know. Does all pumps with pwm / analog to control?
anderzon_
anderzon_
rrodriguess
Anderzon_
Have you found a solution? Have you tryed?
I may have a few Jebao DC. I can test it with RA, and if you want, I can send to you.
where are you from? What model do you need?
Rafa
Rafa
