Two float switch on the same port
PostPosted: Sat Oct 14, 2017 10:43 am
Hi there
I use float switchs as a fail safe for both my Automatic Water Change and my "roberto flow". It is well know that float switch has a short life, and sooner or later tends to fail.
Question. Can I connect two float switch in the same connector? I mean, just attaching the electrical cables and using the same "port". This way, if a float switch fails in the AWC, I still have the other one working and preventing a flood.
My superficial and ridiculous knowledge says that as they work with electrical signals, would be no problem doing that. Am I right?
Best regards
Rafa
PostPosted: Sat Oct 14, 2017 6:28 pm
Do you mean both in serial?
Can you draw something and post just to be sure?
PostPosted: Sun Oct 15, 2017 5:08 am
Roberto
This way: They would monitor the same spot, one backing up the other.
float switch.png (78.5 KiB) Viewed 3154 times
PostPosted: Sun Oct 15, 2017 5:59 am
sounds like he wants them to be run in parallel.
PostPosted: Sun Oct 15, 2017 9:03 am
yeah. It should work just fine
PostPosted: Sun Oct 15, 2017 11:33 am
Tks Roberto
Tks Binder
PostPosted: Tue Nov 14, 2017 11:29 pm
Float switches shouldn't fail often.
Most people put way too much voltage or current through switches.
Float switches always need to be in series. If you are in parallel and one float gets stuck in the on position the other will not be a fail safe as current will have a way to flow.
Return to Standard
Users browsing this forum: No registered users and 5 guests
