Hi Everyone,
Excited and totally new to RA scene from Australia!
I have the RA Star which came with a relay box with Mini-USB connector. It seems that the plastic cover is mis-aligned with the port. So I can't actually plug-in the cable.
Has anyone else had this issue? If so how did you solve it?
I know that I can simply dremmel the hole bigger, but I'm worried that surface mounted USB connector will fall off unless the cut-out is helping to hold the plug in place.
Any thoughts will be greatly appreciated!
Cheers,
Ed
USB port blocked on relay box
- FullSizeRender-1.jpg (469.47 KiB) Viewed 4329 times
Re: USB port blocked on relay box
It shouldn't be like that.
Best way is to just open the plastic and move it to pop into the hole correctly.
Thanks!!
I opened it up today and found that the board had no screws holding it down to the risers.
I simply pushed the board down. It seems to stay there without any screws needed. All good.
