Portal, data logging, app issues
Hi, new reef angel owner here [used unit - new owner]
I got my wifi set up to where the Android app will show data while on my home network, but not outside of the network.
My computer is able to access the portal using my internal and external IP, and update data from inside or outside of my home network.
My phone is not able to [through chrome app] display/update data from the controller.
Port forwarding for port 2000 is open and working [hence I can access it from my work computer for example]
The portal on the website is not working. It does not show me any parameters. Connection Status: Unreachable
My code includes the portal("reefoffillory") and ddns(home). I am also unable to access anything using http://reefoffillory-home.myreefangel which is what my code is set up to direct
I also don't get any data for graphs, and I would like to be able to access/save/download data which will pull every [# of minutes] so That I can correlate changes in my tank with activities such as dosing/lights on/off, refugium light on/off etc.
Any help is greatly appreciated! I'm happy to have figured out port forwarding. I messed up my network about 5 times before I got it to work from outside of my network. The Portal and ddns has never worked for me since getting the controller.
Austin
Austin
Re: Portal, data logging, app issues
When I access the page using my external [or internal] IP + port/wifi I can't get any graphs either. I get a 'No data to display' message.
I was also hoping to maybe get an Amazon fire tablet to hook up to the controller and keep in/on the tank cabinet. Will this work?
Try deleting the ddns line.
I think that is broken when we switched servers.
I will try that when I get home tonight. The setup wizard automatically added that into my code that I uploaded.rimai wrote:Try deleting the ddns line.
Any idea why the android app won't connect to the controller from outside the network, but I can get the info [and control outlets] from outside the server using my IP on my work computer?
Any ideas about logging/why graphing isn't working? - Is this related to the server?
Yes, graph is but the android is not.
The android phone should work since your work computer is able to.
i would make sure you have the right ip in the android app. the setup can default to an internal network address or it will default to using the ddns value for the domain name. so most likely the configuration needs to be updated in the app for it to work properly. check the settings page to see what it is set to.
I had a 5 where there should have been a 6, for my External IP address. Got that part fixed! Thanks for pointing me to the IP configurationbinder wrote:i would make sure you have the right ip in the android app. the setup can default to an internal network address or it will default to using the ddns value for the domain name. so most likely the configuration needs to be updated in the app for it to work properly. check the settings page to see what it is set to.
ReefAngel.AddStandardMenu(); // Let's use 2014 Screen
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port5 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardLights( Port3,8,30,21,0 );
ReefAngel.StandardLights( Port4,8,37,20,54 );
ReefAngel.Portal( "reefoffillory" );
Portal with above code
- Screenshot_20171102-191446.png (101.28 KiB) Viewed 7558 times
Ahhh. I just realized you bought this unit used.
You will need to update the wifi attachment to point to the correct server:
When doing this on Tera Term i'm getting 'Stary WiFly module configuration'rimai wrote:Ahhh. I just realized you bought this unit used.
I have the Wifi Module plugged in to the computer, green light is flashing
I changed it to COM3, and now it's slowly going through numbers after 'ftp:##:wait 'AOK'reefoffillory wrote:When doing this on Tera Term i'm getting 'Stary WiFly module configuration'rimai wrote:Ahhh. I just realized you bought this unit used.
Got through it to where it gave me the option to 'Start WiFly module configuration' again, so I plugged the WiFi attachment back into the Reef Angel and the portal's still not working. My IP [internal and external] is still working though
Is there a way for me to log/store the data from my reef angel through my Internal.IP:2000/wifi or External.IP:2000/wifi?
And/Or auto-update and receive messages based upon parameters?
Is this what you're looking for?rimai wrote:Can you post the log of tera term?
x=0
while x<>121
messagebox 'Start WiFly module configuration' 'Webscan Config Program'
;this macro all sent with 5 msec character delay
timeout=10
send '$$$'
wait 'CMD'
sendln 'factory RESET'
wait 'Set Factory Defaults'
sendln 'reboot'
wait '*READY*'
; Begin user settings
send '$$$'
wait 'CMD'
sendln 'set ftp address 198.175.253.161'
wait'AOK'
sendln 'save'
wait 'config'
sendln 'set wlan ssid Matties$2.4'
wait 'AOK'
sendln 'set wlan pass Password'
wait 'AOK'
sendln 'set option deviceid ReefAngelWifi'
wait 'AOK'
sendln 'set w j 1'
wait 'AOK'
sendln 'set c c 0'
wait 'AOK'
sendln 'set c r 0'
wait 'AOK'
sendln 'set c o 0'
wait 'AOK'
sendln 'set i d 1'
wait 'AOK'
sendln 'set c i 3'
wait 'AOK'
sendln 'set dns name www.reefangel.com'
wait 'AOK'
wait 'AOK'
sendln 'set i r 80'
wait 'AOK'
sendln 'set i f 0x06'
wait 'AOK'
sendln 'set s t 0x10'
wait 'AOK'
sendln 'set u m 2'
wait 'AOK'
sendln 'set i p 2'
wait 'AOK'
sendln 'set u b 57600'
wait 'AOK'
sendln 'set s p 0'
wait 'AOK'
sendln 'set c s 1420'
wait 'AOK'
sendln 'save'
wait 'config'
sendln 'save user'
wait 'user'
sendln'reboot'
;inputbox 'Configure another module (y/n)' 'WiFly Config Program'
; convert inputstr to ASCII int value
; str2code x inputstr
endwhile
I changed the baudrate and it did something different this time. That might have been the issue
CMD
factory RESET
<4.41> reboot
*Reboot*CMD
AOK
<4.41> save
Storing in config
<4.41> set wlan ssid Matties$2.4
AOK
<4.41> set wlan pass Password
AOK
AOK
<4.41> set w j 1
AOK
<4.41> set c c 0
AOK
<4.41> set c r 0
AOK
<4.41> set c o 0
AOK
<4.41> set i d 1
AOK
<4.41> set c i 3
AOK
<4.41> set dns name http://www.reefangel.com
AOK
<4.41> set i h 104.36.18.155
AOK
<4.41> set i r 80
AOK
<4.41> set i f 0x06
AOK
<4.41> set s t 0x10
AOK
<4.41> set u m 2
AOK
<4.41> set i p 2
AOK
<4.41> set u b 57600
AOK
<4.41> set s p 0
AOK
<4.41> set c s 1420
AOK
<4.41> save
Storing in config
<4.41> save user
Storing in user
<4.41> reboot
*Reboot*HTTP/1.1 400 Bad Request
Content-Type: text/html; charset=us-ascii
Server: Microsoft-HTTPAPI/2.0
Date: Fri, 03 Nov 2017 02:41:07 GMT
Connection: close
Content-Length: 326
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN""http://www.w3.org/TR/html4/strict.dtd">
<HTML><HEAD><TITLE>Bad Request</TITLE>
<META HTTP-EQUIV="Content-Type" Content="text/html; charset=us-ascii"></HEAD>
<BODY><h2>Bad Request - Invalid Verb</h2>
<hr><p>HTTP Error 400. The request verb is invalid.</p>
</BODY></HTML>
Date: Fri, 03 Nov 2017 02:41:23 GMT
Connection: close
Content-Length: 326
</BODY></HTML>
I believe the Bad Requests came when I hit ctrl+C to to copy the text so that I could paste it here.
factory RESET
<4.41> reboot
*Reboot*CMD
AOK
<4.41> save
Storing in config
AOK
AOK
AOK
<4.41> set w j 1
AOK
<4.41> set c c 0
AOK
<4.41> set c r 0
AOK
<4.41> set c o 0
AOK
<4.41> set i d 1
AOK
<4.41> set c i 3
AOK
AOK
AOK
<4.41> set i r 80
AOK
<4.41> set i f 0x06
AOK
<4.41> set s t 0x10
AOK
<4.41> set u m 2
AOK
<4.41> set i p 2
AOK
AOK
<4.41> set s p 0
AOK
<4.41> set c s 1420
AOK
<4.41> save
Storing in config
<4.41> save user
Storing in user
<4.41> reboot
Connection: close
Content-Length: 326
</BODY></HTML>
Connection: close
Content-Length: 326
</BODY></HTML>
Good. Try to use it now.
It takes 5 minutes for the connection to go through. So, please allow 5 minutes before you check if the portal received any data.
awesome - it's working now! Thanks Roberto!
rimai wrote:Good. Try to use it now.
Got the portal working, and the app is working when I open it manually, but I keep getting error notifications on the app
Error 15: Timeout connecting to [IP address]
Error 13: Software caused connection abort
Error 13
Error 15
Error 13
Error 15
Error 13
Error 13: timeout
Error 13: No route to host
Error 13: Unexpected status line:GET / status/submitp.aspx?t1=771&t2=771&t3=771&ph761
I've also had problems with the skimmer/ATO not doing the delay after feeding/water change mode. I used the wizard to set up my code, and set the skimmer to have a 15min delay, the ATO to have a 20min delay.
I don't see anything in the code though to tell the controller to do the delays?
Also, I can't seem to be able to set my refugium light for anything less than 'opposite of display tank light outlet'
I'd like to be able to run my refugium for 8hours instead of 12 hours. Is this not possible using the wizard?
rimai wrote:Can you post your code?
I changed the part about the standard menu [as advance as my arduino/coding knowledge goes] and I changed the last part about the portal [that you said to do earlier]#include <ReefAngel_Features.h>
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.LightsOnPorts = Port3Bit | Port4Bit | Port8Bit;
ReefAngel.DayLights( Port4 );
ReefAngel.Relay.DelayedOn( Port5 );
ReefAngel.Relay.DelayedOn( Port7 );
ReefAngel.Relay.Set( Port8, !ReefAngel.Relay.Status( Port4 ) );
ReefAngel.Portal ( "reefoffillory" );
I got this coding after using the Wizard
Well, you are using internal memory code and we can't see the settings you are using.
But, I just reread the post and there is no such thing as delayed start after feeding in the wizard.
For lights, if you use hard coded settings, you can pick the time to start and stop.
rimai wrote:Well, you are using internal memory code and we can't see the settings you are using.
I must have misunderstood the wording from the wizard, I thought it said under 'delayed start' that it's the amount of time that outlets are shut off after entering feeding and/or waterchange mode.
Is it better to use internal memory code or another type? I'm guessing this is in relation to the second screen of the wizard? I don't really need to be able to adjust the settings in the portal - I don't mind hooking my laptop up to the RA in order to change settings
delayed start is the amount of time the outlet remains OFF after one of the following: exiting water change mode, feeding mode and controller start up
so if you set port1 to have a 1 minute delayed start, it won’t turn on until 1 minute after you have 1 of the 3 previously mentioned scenarios.
this is useful if you have a powerhead that is out of the water during water changes and it takes your return pump a minute to get the water level back up to normal. so you wouldn’t want that powerhead on and running out of the water immediately after your water change.
That was how I intended to use it, I wanted my skimmer to stay off for 15 minutes, and my ATO to stay off for 20 minutes (how I set it up in the wizard) but it's not working, going to try again sometime this weekbinder wrote:delayed start is the amount of time the outlet remains OFF after one of the following: exiting water change mode, feeding mode and controller start up
Unless someone changed the libraries, the delayedstart is only applicable to power on delays.
I tried searching the forum for information, but couldn't find anything. Am I able to download the data in the portal history to a form which is able to be manipulated such as a comma delimited/excel etc. file?rimai wrote:Unless someone changed the libraries, the delayedstart is only applicable to power on delays.
I'd like to be able to log my data for more than 3 days at a time, even if that means I have to download data every 3 days and compile it into a spreadsheet myself.
Is there already the capability to do this? I only see the option on the webchart to export image files
Sure. You can get a json formatted file.
http://forum.reefangel.com/status/jsonp ... &filter=t1
