Wifi - reinitialise
Wifi - reinitialise
Hi all,
I'm overseas for an 8 week trip. We've been away for 2 weeks and my RA has fallen offline.
I got my house sitter to reboot routers/wifi etc but the RA wifi module hasn't reconnected...
What's the simplest way I can get the house sitter to reinit the wifi? would an RA reboot work? or even a power cycle from the wall?
Suggestions?
Suggestions?
Re: Wifi - reinitialise
Power cycle probably the easiest. Could also unplug and replug the wifi module.
Roberto, is it possible to send a reboot to the wifi from the controller we could add a menu or automate it say once per day if someone wanted
Send $$$ then send reboot/n
I think this should do it.
It's just like when you set it up with putty.
So technically it's even possible to configure the module from the RA? Like if we had ReefAngel.WiFi.SSID("ssid", "key"); ?
rimai wrote:Send $$$ then send reboot/n
hi there. Sorry to bring this up.. iveno once asked If It is possible to reboot the wifi module from the RA and Roberto just answered the above.
What is the C++ command to send the $$$ and the Reboot/n?
Is it really possible to reboot the wifi module from RA?
Recentelly my wifi module keep loosing connection and give me a blinking blue led. Have to unplug the module from the RA+ or unplug everything from the wall... It would be nice to be able to reboot the wifi module from time to time...
That's what is happening
[youtube]https://youtu.be/4nU7BM2rFbA[/youtube]
Rafa
Hi
Found this other thread
http://forum.reefangel.com/viewtopic.ph ... +RA#p19989
Is that it? This code reboots the Wifi module?
Best Regards
Rafa
if (millis()%3600000<500)
Serial.print("$$$");
wdt_reset();
delay(700);
wdt_reset();
Serial.println("reboot");
Best Regards
Rafa
Hi Roberto
I will try both Serial.println("reboot"); and Serial.println("reboot/n"); and post the results.
Did you have the chance to watch https://youtu.be/4nU7BM2rFbA ?
Best regards
Rafa
Best regards
Rafa
Hi Roberto
Upload this code and worked just fine:
It reinitialises the wifi module. I still don't know what makes it act like this https://youtu.be/4nU7BM2rFbA though.
wdt_reset();
delay(700);
wdt_reset();
