connection issue with wifi
Mayur
Hi
i am not able to connect to wifi using pc/android/iphone it was working fine till yestarday
android error= Error 13: host unreachable :192.168.100:2000
iphone error =Unable to process controller data
Google Chrome =This site can’t be reached 192.168.1.100 took too long to respond.ERR_CONNECTION_TIMED_OUT
on wifi attachment green light is blinking
Re: connection issue with wifi
Looks like your router assigned another ip address to your wifi attachment.
Mayur
ip is same
Mayur
water damage controller unit or wifi attachment ?
controller is located far from sump no signs of water
how can i check which one is damage ?
Mayur
So, we know RA is working fine.
Can you setup the wifi attachment?
Mayur
So, maybe the cable between RA and wifi attachment went bad.
Mayur
just now tryed to connect with the breadboard jumber cable the green light is blinking on wifi attachment but unable to open the 192.168.1.100:2000/wifi
Doesn't make sense.
If everything is working....
Can you post the log for the wifi setup?
Mayur
Opening Serial Port...
Connected to serial port COM3
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 2 79680 3 WiFly_GSX-2.36
< 22 1052 10 config
< 23 1052 10 user
< 24 88548 3 NO NAME
< 25 88548 3 wifly-GSX-441-r1057
< 34 83648 3 WiFly_GSX-2.45
< 79 46632 3 wps_app-GSX-131
< 80 66240 3 eap_app-GSX-101
> load user
< 81 74920 3 web_app-GSX-106
< 82 37282 0 web_config.html
< 83 512 0 link.html
< 107 Free, Boot=25, Backup=24
< <4.41>
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> save
< save
< Storing in config
< <4.41>
> set o d ReefAngelWifi
< set o d ReefAngelWifi
< AOK
< <4.41>
< set w l 5
> set w l 5
< AOK
< <4.41>
> set w s iBall-Baton$1
< set w s iBall-Baton$1
< AOK
< <4.41>
> set w p @9224284117@9004077372@
< set w p @9224284117@9004077372@
< AOK
< <4.41>
< AOK
< <4.41>
< set ftp address 198.175.253.161
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> reboot
< reboot
< CMD
< DHCP in 5378ms, lease=604800s
< IF=UP
< DHCP=ON
< IP=192.168.1.100:2000
< NM=255.255.255.0
< GW=192.168.1.1
< Listen on 2000
> show n
< show n
< SSid=iBall-Baton 1
< Chan=9
< Assoc=OK
< Rate=12, 24Mb
< Auth=OK
< Mode=MIXED
< DHCP=OK,renew=453600
< Boot=5439
< Time=FAIL
< Links=1
< <4.41>
> get i
< get i
< IF=UP
< DHCP=ON
< NM=255.255.255.0
< GW=192.168.1.1
< HOST=198.171.134.6:80
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.41>
> reboot
< reboot
Removing connection to COM3
Found router iB-WRB300N
Port 2000 is now being forwarded to 192.168.1.100
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 22 1052 10 config
< 23 1052 10 user
> load user
< <4.41>
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> save
< save
< Storing in config
< <4.41>
< AOK
< <4.41>
< set w l 5
> set w l 5
< AOK
< <4.41>
< AOK
< <4.41>
< AOK
< <4.41>
< AOK
< <4.41>
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> reboot
< reboot
< CMD
< IF=UP
< DHCP=ON
< NM=255.255.255.0
< GW=192.168.1.1
< Listen on 2000
> show n
< show n
< Chan=9
< Assoc=OK
< Rate=12, 24Mb
< Auth=OK
< Mode=MIXED
< Boot=5439
< Time=FAIL
< Links=1
< <4.41>
> get i
< get i
< IF=UP
< DHCP=ON
< NM=255.255.255.0
< GW=192.168.1.1
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.41>
> reboot
< reboot
Yeap. If RA is working and wifi attachment is working, it can only be the cable.
Mayur
check the attach pic for wiring diagram
still not working
getting error 13: No route to host
still not working
Mayur
code was change 1 week before but it was working fine
how to check if controller is sending data to wifi attachment in serial monitor
Open serial monitor at 57600 baud.
Then, manke sure you have Both CR and LF.
Type "GET / HTTP " and click send.
Mayur
unabe to upload code now
Watchdog Timer
Version Menu
Simple Menu
Binary sketch size: 28,296 bytes (of a 258,048 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM3 -b115200 -D -V -Uflash:w:C:\Users\MAYUR\AppData\Local\Temp\build1336863122691777432.tmp\InitialInternalMemory.cpp.hex:i
Using Port : \\.\COM3
Using Programmer : stk500v2
Overriding Baud Rate : 115200
avrdude: Recv:
avrdude done. Thank you.
Watchdog Timer
Version Menu
Simple Menu
avrdude: Recv:
Mayur
got this in serial monitor
HTTP/1.1 200 OK
Server: ReefAngel
Cache-Control: no-store, no-cache, must-revalidate
Pragma: no-cache
Access-Control-Allow-Origin: *
Access-Control-Allow-Methods: GET
Connection: close
Content-Type: text/html
Content-Length: 41
<h1>Reef Angel Controller Web Server</h1>
HTTP/1.1 200 OK
Server: ReefAngel
Pragma: no-cache
Connection: close
Content-Length: 41
That means the controller is sending data to WiFi attachment.
I'm at a loss why it is not working.
All pieces are working correctly.
Mayur
finally found the issue it was wifi router got it replace with new one later found out the AP Isolation was enable 2 days before it might be the problem
how to check if its sending data to portal ?
Mayur
Reef Angel wifi address: 192.168.1.100:2000
My reefangelid:
Mayur
Connection Status:
Unreachable Address
Last Update:
6/22/2015, 5:24:13 PM
Displaying data from:
Webbanner database
My reefangelid:
Mayur
Connection Status:
Unreachable Address
Last Update:
Webbanner database
Mayur
reefangel client log
*****12/4/2017 1:26:48 AM*****
Message:
The communication object, System.ServiceModel.Channels.ServiceChannel, cannot be used for communication because it has been Aborted.
StackTrace:
Server stack trace:
at System.ServiceModel.Channels.CommunicationObject.ThrowIfDisposedOrNotOpen()
at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs, TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannelProxy.InvokeService(IMethodCallMessage methodCall, ProxyOperationRuntime operation)
at System.ServiceModel.Channels.ServiceChannelProxy.Invoke(IMessage message)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at ReefAngelWCFListener.IReefAngelCallback.HandleParams(ReefAngelParams paras)
at ReefAngelWCFListener.ReefAngelListener.<>c__DisplayClass10.<SendParams>b__f(Object )
*****12/4/2017 1:27:28 AM*****
Message:
Inside WifiSend:
The underlying connection was closed: An unexpected error occurred on a receive.
StackTrace:
at System.Net.WebClient.DownloadDataInternal(Uri address, WebRequest& request)
at System.Net.WebClient.DownloadString(Uri address)
at System.Net.WebClient.DownloadString(String address)
at ReefAngelWCFListener.ReefAngelListener.WifiSend()
Message:
StackTrace:
Server stack trace:
Message:
Inside WifiSend:
StackTrace:
Mayur
Is it just portal updates?
Are you able to connect to the ip address?
Mayur
Mayur
Mayur
