connection issue with wifi
PostPosted: Thu Nov 30, 2017 8:32 am
Hi
i am not able to connect to wifi using pc/android/iphone it was working fine till yestarday
android error= Error 13: host unreachable :192.168.100:2000
iphone error =Unable to process controller data
Google Chrome =This site can’t be reached 192.168.1.100 took too long to respond.ERR_CONNECTION_TIMED_OUT
on wifi attachment green light is blinking
PostPosted: Thu Nov 30, 2017 10:12 am
Looks like your router assigned another ip address to your wifi attachment.
PostPosted: Thu Nov 30, 2017 10:33 am
ip is same
PostPosted: Thu Nov 30, 2017 10:48 am
Humm.
Could it be water damage?
Or the cable somehow?
PostPosted: Thu Nov 30, 2017 11:20 am
water damage controller unit or wifi attachment ?
controller is located far from sump no signs of water
how can i check which one is damage ?
PostPosted: Thu Nov 30, 2017 11:25 am
ReefAngel client is working fine with usb
PostPosted: Thu Nov 30, 2017 11:35 am
So, we know RA is working fine.
Can you setup the wifi attachment?
PostPosted: Thu Nov 30, 2017 11:37 am
yes with the usb cable i was able to setup the wifi unit
PostPosted: Thu Nov 30, 2017 11:39 am
So, maybe the cable between RA and wifi attachment went bad.
PostPosted: Thu Nov 30, 2017 11:42 am
just now tryed to connect with the breadboard jumber cable the green light is blinking on wifi attachment but unable to open the 192.168.1.100:2000/wifi
Next
Return to For New Members
