Doesn't make sense.
If everything is working....
Can you post the log for the wifi setup?
connection issue with wifi
• Page 2 of 4 • 1, 2, 3, 4
Opening Serial Port...
Connected to serial port COM3 > $$$ < CMD > ls < ls < < FL# SIZ FLAGS < 2 79680 3 WiFly_GSX-2.36 < 22 1052 10 config < 23 1052 10 user < 24 88548 3 NO NAME < 25 88548 3 wifly-GSX-441-r1057 < 34 83648 3 WiFly_GSX-2.45 < 79 46632 3 wps_app-GSX-131 < 80 66240 3 eap_app-GSX-101 > load user < 81 74920 3 web_app-GSX-106 < 82 37282 0 web_config.html < 83 512 0 link.html < 84 7268 0 logo.png < < 107 Free, Boot=25, Backup=24 < <4.41> < load user < AOK < <4.41> > save < save < Storing in config < <4.41> > save < save < Storing in config < <4.41> > set o d ReefAngelWifi < set o d ReefAngelWifi < AOK < <4.41> < set w l 5 > set w l 5 < AOK < <4.41> > set w s iBall-Baton$1 < set w s iBall-Baton$1 < AOK < <4.41> > set w p @9224284117@9004077372@ < set w p @9224284117@9004077372@ < AOK < <4.41> > set w k 00000000000000000000000000 < set w k 00000000000000000000000000 < AOK < <4.41> > set ftp address 198.175.253.161 < set ftp address 198.175.253.161 < AOK < <4.41> > save < save < Storing in config < <4.41> > reboot < reboot > $$$ < CMD < DHCP in 5378ms, lease=604800s < IF=UP < DHCP=ON < IP=192.168.1.100:2000 < NM=255.255.255.0 < GW=192.168.1.1 < Listen on 2000 > show n < show n < SSid=iBall-Baton 1 < Chan=9 < Assoc=OK < Rate=12, 24Mb < Auth=OK < Mode=MIXED < DHCP=OK,renew=453600 < Boot=5439 < Time=FAIL < Links=1 < <4.41> > get i < get i < IF=UP < DHCP=ON < IP=192.168.1.100:2000 < NM=255.255.255.0 < GW=192.168.1.1 < HOST=198.171.134.6:80 < PROTO=TCP, < MTU=1524 < FLAGS=0x6 < TCPMODE=0x0 < BACKUP=0.0.0.0 < <4.41> > reboot < reboot Removing connection to COM3 --------------------------------------------------------------------- Your Reef Angel Wifi Attachment is now configured with the settings provided. --------------------------------------------------------------------- If the blue LED is still blinking, it means that the Reef Angel Wifi Attachment could not connect to your wifi network. Found router iB-WRB300N Port 2000 is now being forwarded to 192.168.1.100 |
Yeap. If RA is working and wifi attachment is working, it can only be the cable.
check the attach pic for wiring diagram
still not working getting error 13: No route to host
Are you sure you didn't change the code?
code was change 1 week before but it was working fine
how to check if controller is sending data to wifi attachment in serial monitor |
Open serial monitor at 57600 baud.
Then, manke sure you have Both CR and LF. Type "GET / HTTP " and click send. Roberto.
unabe to upload code now
The following features were automatically added: Watchdog Timer Version Menu The following features were detected: Simple Menu Binary sketch size: 28,296 bytes (of a 258,048 byte maximum) C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM3 -b115200 -D -V -Uflash:w:C:\Users\MAYUR\AppData\Local\Temp\build1336863122691777432.tmp\InitialInternalMemory.cpp.hex:i avrdude: Version 6.0, compiled on Apr 6 2012 at 19:29:19 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2009 Joerg Wunsch System wide configuration file is "C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf" Using Port : \\.\COM3 Using Programmer : stk500v2 Overriding Baud Rate : 115200 Rebooting Reef Angel Controller avrdude: Send: . [1b] . [01] . [00] . [01] . [0e] . [01] . [14] avrdude: Recv: avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_getsync(): timeout communicating with programmer avrdude done. Thank you. |
got this in serial monitor
HTTP/1.1 200 OK Server: ReefAngel Cache-Control: no-store, no-cache, must-revalidate Pragma: no-cache Access-Control-Allow-Origin: * Access-Control-Allow-Methods: GET Connection: close Content-Type: text/html Content-Length: 41 <h1>Reef Angel Controller Web Server</h1> |
That means the controller is sending data to WiFi attachment.
I'm at a loss why it is not working. All pieces are working correctly. Roberto.
