connection issue with wifi
PostPosted: Sun Dec 03, 2017 11:40 am
finally found the issue it was wifi router got it replace with new one later found out the AP Isolation was enable 2 days before it might be the problem
how to check if its sending data to portal ?
PostPosted: Sun Dec 03, 2017 12:17 pm
Reef Angel wifi address: 192.168.1.100:2000
My reefangelid:
Mayur
Connection Status:
Unreachable Address
Last Update:
6/22/2015, 5:24:13 PM
Displaying data from:
Webbanner database
PostPosted: Sun Dec 03, 2017 1:00 pm
reefangel client log
*****12/4/2017 1:26:48 AM*****
Message:
The communication object, System.ServiceModel.Channels.ServiceChannel, cannot be used for communication because it has been Aborted.
StackTrace:
Server stack trace:
at System.ServiceModel.Channels.CommunicationObject.ThrowIfDisposedOrNotOpen()
at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs, TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannelProxy.InvokeService(IMethodCallMessage methodCall, ProxyOperationRuntime operation)
at System.ServiceModel.Channels.ServiceChannelProxy.Invoke(IMessage message)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at ReefAngelWCFListener.IReefAngelCallback.HandleParams(ReefAngelParams paras)
at ReefAngelWCFListener.ReefAngelListener.<>c__DisplayClass10.<SendParams>b__f(Object )
*****12/4/2017 1:27:28 AM*****
Message:
Inside WifiSend:
The underlying connection was closed: An unexpected error occurred on a receive.
StackTrace:
at System.Net.WebClient.DownloadDataInternal(Uri address, WebRequest& request)
at System.Net.WebClient.DownloadString(Uri address)
at System.Net.WebClient.DownloadString(String address)
at ReefAngelWCFListener.ReefAngelListener.WifiSend()
PostPosted: Thu Dec 07, 2017 11:41 am
Still the same issue portal not getting update
PostPosted: Thu Dec 07, 2017 11:43 am
Is it just portal updates?
Are you able to connect to the ip address?
PostPosted: Thu Dec 07, 2017 11:49 am
Yes I can connect to ip address
192.168.1.100:2000/wifi
PostPosted: Thu Dec 07, 2017 12:01 pm
Ok.
So, you need to update the wifi attachment.
viewtopic.php?f=3&t=4601
PostPosted: Thu Dec 07, 2017 12:24 pm
blue light keep flashing after update
PostPosted: Thu Dec 07, 2017 12:28 pm
Did you edit the file with your own ssid and passphrase?
PostPosted: Thu Dec 07, 2017 12:30 pm
yes
the program keep running in loop
PreviousNext
Return to For New Members
