heater not turning off
PostPosted: Sun Dec 10, 2017 10:45 am
now that I have reprogrammed my controller after dealing with my lights issue my heater doesn't shut off when it gets above the desired temp. ive tried setting it to all three temp probes and none of them turn the heater off. I set the code up with the internal memory. here is the code I have loaded.
    ReefAngel.AddSalinityExpansion();  // Salinity Expansion Module
    ReefAngel.WaterChangePorts = Port3Bit;
    ReefAngel.Relay.On( Port4 );
    ReefAngel.StandardATO( Port3 );
    ReefAngel.MoonLights( Box1_Port6 );
    ReefAngel.PWM.Channel0PWMSlope();
    ReefAngel.PWM.Channel1PWMSlope();
    ReefAngel.PWM.Channel2PWMSlope();
    ReefAngel.PWM.Channel3PWMSlope();
    ReefAngel.PWM.Channel4PWMSlope();
    ReefAngel.PWM.Channel5PWMSlope();
    ReefAngel.Portal( "jjdezek" );
PostPosted: Sun Dec 10, 2017 11:15 am
Hard to tell with internal memory code.
What values do you have?
Did you try hard coding it?
PostPosted: Mon Dec 11, 2017 2:59 pm
I have it the same as I had in the past. Turn on at 77.0 and turn off at 77.1. Since I redid the code it hasn’t been working right. Like right now my tank is at 77.3 and the heater is on.
Return to Standard
