The display is a 96x48x33H 600Gal commercial glass tank made my Miracles Aquariums. It sits in a recreation room that measures 30x20ft and has a decorative concrete floor. The system itself is a work in progress but is approaching fully operational after 1.5 years of work. The system is plumbed into the basement where it has a dedicated filtration, propagation, and quarantine room. This room consists of...
Tied to main display
100Gal Custom AGE acrylic sump
100Gal 48x48x10" Coral Flat
50Gal 48x20x10" Coral Flat
78" Tall RK2 Commercial Skimmer
Masterflex fed Calcium Reactor
Masterflex dosing pump for Vodka Dosing
Aquamedic Kalk reactor
Vertex Media Reactor
Independent Systems
BTA Propagation System consisting of 6 20Gal All-in-One systems
75Gal QT All-in-One
60Gal QT All-in-One
Support Equipment
Shop Sink - Converts to fragging station
200GPD 9 Stage RODI System
200Gal RODI Storage Tank w/ Closed Loop Dionization
200Gal Saltwater Storage Tank
HRV - Heat Recovery Ventilator - Exchanges house air 3x per day to control humidity but retain heat.
3x 20a Circuits
1x 15a Circuit
Shelving for storage
Storage for 8x boxes of salt
Plans for my ReefAngel
The flexibility of the system is what drew me into the RA world in the first place. I've had the original, the Plus, and will migrate to the Star before this project is complete. I will be monitoring temperature of the room as well as the 11 tanks. ORP, Salinity, PH, and RF for Ecotech Marine Vortechs will be utilized on the 600gal and two coral flats. Lighting and heater control will also be done through the RA.
I would like to mount a tablet to the wall of the room to have the portal displayed. The hope is that I will be able to customize a screen to provide me with critical data from all systems as well as logs to help spot any abnormalities. I am sure other features will be implemented along the way as the system matures.
I'll post some pictures in this thread as time allows. If you want to take a look at the build thread it can be found on RC. http://www.reefcentral.com/forums/showt ... ?t=2578543
Thanks for taking a look, feels good to be back
Here is the live stream! It should be up between Noon and Midnight MST daily. Best watched in 1080p.
https://www.youtube.com/embed/live_stre ... pIlN7h2Ldw
