Simple code to start out
Ask in here.
PostPosted: Sun Dec 24, 2017 4:12 pm
Ok to start out just custom name a port. Like port 4 to Return/Refugium pump. When I get my WiFi mod can I start and stop any port with the app? I can hopefully with an example I was talking about port 4 to Return/Refugium pump do any other ones I want to. Thanks for the help.
PostPosted: Sun Dec 24, 2017 8:27 pm
Swampfox wrote:Ok to start out just custom name a port. Like port 4 to Return/Refugium pump. When I get my WiFi mod can I start and stop any port with the app? I can hopefully with an example I was talking about port 4 to Return/Refugium pump do any other ones I want to. Thanks for the help.
Custom names for a port are handled on the portal. you just need to login to the portal and change the name there.
Yes, with all the apps and the wifi module you can toggle (start / stop) any port.
PostPosted: Mon Dec 25, 2017 8:32 am
The problem is I don’t have a WiFi module so I can get on the portal.
PostPosted: Mon Dec 25, 2017 3:26 pm
Swampfox wrote:The problem is I don’t have a WiFi module so I can get on the portal.
Ok, you have a misunderstanding then.
You don't have to have a wifi module to view the Portal section. You can still goto the Portal without having a wifi module but you just won't see any data and be able to do much. It's towards the top of the screen, there's a link that says "Portal" in between the "Forum" and "Download" sections.
Where were you wanting the Name of a port to be?
This will help to be able to better answer your question.
PostPosted: Mon Dec 25, 2017 3:31 pm
When I hook up my controller to the computer by the usb cable. I click labels I get this “Only available with valid wifi address. Please make sure your controller is sending data to the Portal web server.”
PostPosted: Mon Dec 25, 2017 4:41 pm
What program are you using?
PostPosted: Mon Dec 25, 2017 5:52 pm
The only program I have used is the wizard.
PostPosted: Tue Dec 26, 2017 6:38 am
ok. the labels are only used on the portal. so I honestly wouldn't worry about labels right now.
Return to How do I code ...
