Simple code to start out
Swampfox
Ok to start out just custom name a port. Like port 4 to Return/Refugium pump. When I get my WiFi mod can I start and stop any port with the app? I can hopefully with an example I was talking about port 4 to Return/Refugium pump do any other ones I want to. Thanks for the help.
- Contact:
Re: Simple code to start out
Custom names for a port are handled on the portal. you just need to login to the portal and change the name there.Swampfox wrote:Ok to start out just custom name a port. Like port 4 to Return/Refugium pump. When I get my WiFi mod can I start and stop any port with the app? I can hopefully with an example I was talking about port 4 to Return/Refugium pump do any other ones I want to. Thanks for the help.
Yes, with all the apps and the wifi module you can toggle (start / stop) any port.
Swampfox
- Contact:
Ok, you have a misunderstanding then.Swampfox wrote:The problem is I don’t have a WiFi module so I can get on the portal.
You don't have to have a wifi module to view the Portal section. You can still goto the Portal without having a wifi module but you just won't see any data and be able to do much. It's towards the top of the screen, there's a link that says "Portal" in between the "Forum" and "Download" sections.
Where were you wanting the Name of a port to be?
This will help to be able to better answer your question.
Swampfox
When I hook up my controller to the computer by the usb cable. I click labels I get this “Only available with valid wifi address. Please make sure your controller is sending data to the Portal web server.”
- Contact:
What program are you using?
Swampfox
- Contact:
ok. the labels are only used on the portal. so I honestly wouldn't worry about labels right now.
