Simple code to start out
Ok to start out just custom name a port. Like port 4 to Return/Refugium pump. When I get my WiFi mod can I start and stop any port with the app? I can hopefully with an example I was talking about port 4 to Return/Refugium pump do any other ones I want to. Thanks for the help.
Re: Simple code to start out
Custom names for a port are handled on the portal. you just need to login to the portal and change the name there.Swampfox wrote:Ok to start out just custom name a port. Like port 4 to Return/Refugium pump. When I get my WiFi mod can I start and stop any port with the app? I can hopefully with an example I was talking about port 4 to Return/Refugium pump do any other ones I want to. Thanks for the help.
Yes, with all the apps and the wifi module you can toggle (start / stop) any port.
Ok, you have a misunderstanding then.Swampfox wrote:The problem is I don’t have a WiFi module so I can get on the portal.
You don't have to have a wifi module to view the Portal section. You can still goto the Portal without having a wifi module but you just won't see any data and be able to do much. It's towards the top of the screen, there's a link that says "Portal" in between the "Forum" and "Download" sections.
Where were you wanting the Name of a port to be?
This will help to be able to better answer your question.
When I hook up my controller to the computer by the usb cable. I click labels I get this “Only available with valid wifi address. Please make sure your controller is sending data to the Portal web server.”
What program are you using?
ok. the labels are only used on the portal. so I honestly wouldn't worry about labels right now.
