watch dog timer
ryanmell
watch dog timer
can someone explain what the watchdog timer does and if i should enable it with ragen. my timers for my lights don't seem to be working and i trigged the ato by hand and it worked then later that day it didn't kick my ato pump on so i turned it on through the iphone app to fill it up. i don't have a copy of my pde with me. was more curious about what the watchdog timer does
Re: watch dog timer
WDT is a feature of many microprocessor and is considered a supervisory feature.
Its basic function is to wait for a signal from RA every so often. If the signal is not received, it will consider that there is a failure in the code and it will reset the controller to prevent lock-ups.
http://en.wikipedia.org/wiki/Watchdog_timer
Re: watch dog timer
Post your code when you have a chance.
The ATO also has a timeout feature, where it will kill the ATO off until you manually clear the ATO flag.
This is to prevent pumps from running dry or cause an overflow by dumping the whole fresh water reservoir if the float switch gets stuck or a snail decides to get in the way.
This usually can be seen by the red status led lit in your head unit.
ryanmell
Re: watch dog timer
ya thats what i thought i removed the timeout feature because of the pump i am using which is a toms vacumn pump which doesnt pump a lot of water real fast i have the two floats set up the bottom one wires up and the top one with the wires down, sounds like i should enable the watchdog, the only thing that scares my is i unplgged the unit for a second to move the cord and when i plugged it back in some of the outlets were switched off is there a way to program which outlets you want to be turned on if there is a power failure?
ryanmell
Re: watch dog timer
here's my files
memory
and Pde
memory
Autogenerated file by RAGen (v1.1.0.126), (02/04/2012 22:28)
// Memory_020412_2228.pde
#include <Phillips6610LCDInv.h>
#include <avr/pgmspace.h>
#include <ReefAngel_EEPROM.h>
Phillips6610LCDInv e;
e.lcd_init();
e.lcd_clear(COLOR_WHITE,0,0,132,132);
e.lcd_BacklightOn();
InternalMemory.MHOnHour_write(13);
InternalMemory.MHOffHour_write(21);
InternalMemory.MHDelay_write(0);
InternalMemory.StdLightsOnHour_write(12);
InternalMemory.StdLightsOffHour_write(22);
InternalMemory.ATOTimeout_write(90);
InternalMemory.LEDPWMActinic_write(100);
InternalMemory.LEDPWMDaylight_write(100);
InternalMemory.WM1Timer_write(0);
// display the values
char buf[128];
sprintf(buf, "MH %2d:%02d-%2d:%02d,%d", InternalMemory.MHOnHour_read(), InternalMemory.MHOnMinute_read(),
InternalMemory.MHOffHour_read(), InternalMemory.MHOffMinute_read(),
InternalMemory.MHDelay_read());
e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW, buf);
sprintf(buf, "Std %2d:%02d-%2d:%02d", InternalMemory.StdLightsOnHour_read(), InternalMemory.StdLightsOnMinute_read(),
InternalMemory.StdLightsOffHour_read(), InternalMemory.StdLightsOffMinute_read());
e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*2, buf);
sprintf(buf, "LED A: %d%% D: %d%%", InternalMemory.LEDPWMActinic_read(), InternalMemory.LEDPWMDaylight_read());
e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*3, buf);
sprintf(buf, "WM1: %ds", InternalMemory.WM1Timer_read());
e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*4, buf);
sprintf(buf, "WM2: %ds", InternalMemory.WM2Timer_read());
e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*5, buf);
sprintf(buf, "F: %ds", InternalMemory.FeedingTimer_read());
e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*6, buf);
sprintf(buf, "S: %ds", InternalMemory.LCDTimer_read());
e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*7, buf);
sprintf(buf, "H On: %d -> %d", InternalMemory.HeaterTempOn_read(), InternalMemory.HeaterTempOff_read());
e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*9, buf);
sprintf(buf, "C On: %d -> %d", InternalMemory.ChillerTempOn_read(), InternalMemory.ChillerTempOff_read());
e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*10, buf);
sprintf(buf, "PH %d - %d", InternalMemory.PHMax_read(), InternalMemory.PHMin_read());
e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*11, buf);
delay(10000);
sprintf(buf, "OH: %dF", InternalMemory.OverheatTemp_read());
sprintf(buf, "ATO L: %ds (%dh)", InternalMemory.ATOTimeout_read(), InternalMemory.ATOHourInterval_read());
sprintf(buf, "ATO H: %ds (%dh)", InternalMemory.ATOHighTimeout_read(), InternalMemory.ATOHighHourInterval_read());
sprintf(buf, "DP1: %2d:%02d", InternalMemory.DP1OnHour_read(), InternalMemory.DP1OnMinute_read());
sprintf(buf, " %ds", InternalMemory.DP1Timer_read());
sprintf(buf, "DP2: %2d:%02d", InternalMemory.DP2OnHour_read(), InternalMemory.DP2OnMinute_read());
sprintf(buf, " %ds", InternalMemory.DP2Timer_read());
e.lcd_draw_text(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*8, buf);
delay(10000);
// Autogenerated file by RAGen (v1.0.4.92), (06/03/2011 22:34)
// RA_060311_2234.pde
#define DisplayImages
#define WavemakerSetup
#define DateTimeSetup
#define VersionMenu
#define ATOSetup
#define MetalHalideSetup
#define DirectTempSensor
#define DisplayLEDPWM
#define StandardLightSetup
#include <ReefAngel_Wifi.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
ReefAngel.Relay.On(Port8);
// Specific functions
ReefAngel.StandardATO(Port1);
ReefAngel.MHLights(Port3);
ReefAngel.Skimmer(Port4);
ReefAngel.Wavemaker1(Port5);
ReefAngel.Wavemaker2(Port6);
ryanmell
Re: watch dog timer
i also loaded the memory file first the the pde. also on my controller when i go to the clear ato function all it says is clear ato press exit to cancel there is no ok button or anything
- Contact:
ryanmell
Re: watch dog timer
ya i just sits there and never clears how long should it take to clear
- Contact:
Re: watch dog timer
You must press the joystick button to clear the screen and return to normal functioning. If you do not press the joystick button, it will sit there indefinitely. That's just how that menu option is designed. So you choose to clear the the ATO timeout, it shows that screen, you press the joystick button again to return to normal operations.
Re: watch dog timer
Do you have the float switches mounted in opposite directions?
http://forum.reefangel.com/viewtopic.php?f=7&t=240
ryanmell
Re: watch dog timer
yes i have the switches mounted opposite one wires up and one wires down
Re: watch dog timer
Could it be that they are swapped out?
Try swapping the plugs on the head unit.
ryanmell
Re: watch dog timer
ya i tried that last night night i don't know why there would be a short i they are sealed up good but the red status light clears when i unplug them from the controller
Re: watch dog timer
I remember you mentioned something about disabling timeout. What exactly did you do?
ryanmell
Re: watch dog timer
i just went into the memory settings in ragen and changed both fields to 0 i do have a multimeter i will test them when i get home
Re: watch dog timer
Try using this:
Change 1000 to how many seconds you want timeout to be, except 0.
ReefAngel.StandardATO(Port1,1000);
ryanmell
Re: watch dog timer
i was trying to avoid a timeout since my top off pump only pumps 3 gallons in an hour
Re: watch dog timer
That's fine.
The way I posted, you can have a timeout of as much as 32767 seconds, which is a little over 9 hours.
Timeout is always good to have.
It will prevent your pump from running dry and also could prevent a flood if something tampers with the float switch.
ryanmell
Re: watch dog timer
awesome i will try that when i get home do i need to change the memory file or the pde? the line you posted is from the pde right?
Re: watch dog timer
Yes, PDE.
It will just use the value in the PDE instead of the memory settings.
ryanmell
Re: watch dog timer
thanks that worked now i need to figure out my lights i have a nova extreme pro with 2 switches and they are plugged into two separate outlets with 2 different settings but both come on and turn off at the same time and i can't get my 2nd powerhead to alternate off and on. i want the 1st powerhead to always be on and the second to cycle on and off thanks for all your help this controller is as addicting as the reef tank itself
Re: watch dog timer
What I understood from your code is that you have one switch plugged into port2 and another switch into port 3, correct?
When creating your memory file or updating it with the Client or smartphone apps, make sure to use different times on MH and Standard light schedule.
For the powerheads, they should be alternating, according to these lines in your code:
ryanmell
Re: watch dog timer
ya i think i figured out the lights maybe i added this code
ReefAngel.StandardATO(Port1,1600);
// T5 White
ReefAngel.StandardLights(Port2,13,0,21,0);
//T5 Blue
ReefAngel.StandardLights(Port3,12,0,22,0);
as far as the wavemakers go i want powerhead 1 to always stay on and the 2nd one to have random pattern
// T5 White
//T5 Blue
Re: watch dog timer
You nailed the lights code
The wavemaker:
Add this to setup()
And this to loop()
The wavemaker:
Add this to setup()
randomSeed(analogRead(0));
ReefAngel.Timer[1].SetInterval(random(15,35));
ReefAngel.Timer[1].Start();
ReefAngel.Relay.On(Port5);
