Portal, Uapp, History, etc.
Related to the Portal
paperdesk
Post by paperdesk »
So, I'm trying to figure out a few things.
1. The portal doesn't work for me at all anymore (it's been a while actually).
2. The RA android app and the Uapp work fine, except that the uapp will not display history.
3. I really miss the ability the portal had to see relay history too.
4. Did something change with the portal, or could it be on my end?
Ted
Re: Portal, Uapp, History, etc.
Please update your wifi attachment:
paperdesk
Post by paperdesk »
rimai wrote:Please update your wifi attachment:
I feel like I've done this in the past, but maybe it needs it again. I'll try this and see what happens.
Ted
paperdesk
Post by paperdesk »
I updated the wifi attachment, didn't help. What is supposed to display in Tera Term to show it has completed the update successfully?
An entire log on stuff is suppose to show.
Can you post the log?
paperdesk
Post by paperdesk »
So maybe my Wifi Attachment is now softbricked. I did a bunch of reading in the RA forums, and found a post (http://forum.reefangel.com/viewtopic.ph ... 1&start=50) where you said the SSID cannot have a space in it, and to replace it with a "$" I did that, and ran the macro, and the wifi attachment started going solid yellow and red, and occasionally flashing blue. Every time it flashed blue it shows a handshake fail in Tera Term.
I fussed with it for a while, and couldn't get anywhere. I thought my USB cable may be bad, so I plugged in a second wifi attachment from another tank. I updated the attachment a couple different times without the "$" symbol, and everything worked fine, so I then replaced the SSID space with an "$" and not it has the same problem as the first. Is there anything I can do now? I guess I've substantiated that the "$" symbol is not a good replacement for a space in the SSID.
$ is the correct way.
Not sure what happened.
Can you send the log?
paperdesk
Post by paperdesk »
I can't seem to pull up a log.
Copy and paste what you get on tera term
paperdesk
Post by paperdesk »
*FAIL*, handshake
EAP TRY #3
*FAIL*, handshake
EAP-TLS Client APP version 1.00 10/11/12
*FAIL*, handshake
EAP TRY #2
*FAIL*, handshake
EAP TRY #3
*FAIL*, handshake
*FAIL*, handshake
EAP TRY #2
*FAIL*, handshake
EAP TRY #3
*FAIL*, handshake
*FAIL*, handshake
EAP TRY #2
*FAIL*, handshake
EAP TRY #3
*FAIL*, handshake
paperdesk
Post by paperdesk »
Here is the .ttl file info:
x=0
while x<>121
messagebox 'Start WiFly module configuration' 'Webscan Config Program'
;this macro all sent with 5 msec character delay
timeout=10
send '$$$'
wait 'CMD'
sendln 'factory RESET'
wait 'Set Factory Defaults'
sendln 'reboot'
wait '*READY*'
; Begin user settings
send '$$$'
wait 'CMD'
sendln 'set ftp address 198.175.253.161'
wait'AOK'
sendln 'save'
wait 'config'
sendln 'set wlan ssid YD$Staff'
wait 'AOK'
sendln 'set wlan pass AS44:Efdsse'
wait 'AOK'
sendln 'set option deviceid ReefAngelWifi'
wait 'AOK'
sendln 'set w j 1'
wait 'AOK'
sendln 'set c c 0'
wait 'AOK'
sendln 'set c r 0'
wait 'AOK'
sendln 'set c o 0'
wait 'AOK'
sendln 'set i d 1'
wait 'AOK'
sendln 'set c i 3'
wait 'AOK'
sendln 'set dns name www.reefangel.com'
wait 'AOK'
sendln 'set i h 104.36.18.155'
wait 'AOK'
sendln 'set i r 80'
wait 'AOK'
sendln 'set i f 0x06'
wait 'AOK'
sendln 'set s t 0x10'
wait 'AOK'
sendln 'set u m 2'
wait 'AOK'
sendln 'set i p 2'
wait 'AOK'
sendln 'set u b 57600'
wait 'AOK'
sendln 'set s p 0'
wait 'AOK'
sendln 'set c s 1420'
wait 'AOK'
sendln 'save'
wait 'config'
sendln 'save user'
wait 'user'
sendln'reboot'
;inputbox 'Configure another module (y/n)' 'WiFly Config Program'
; convert inputstr to ASCII int value
; str2code x inputstr
endwhile
Can you send the log of what happens when you hit ok on the button to configure the module?
paperdesk
Post by paperdesk »
CMD
factory RESET
<4.41> reboot
*Reboot*EAP-TLS Client APP version 1.00 10/11/12
*FAIL*, handshake
EAP TRY #2
*FAIL*, handshake
EAP TRY #3
*FAIL*, handshake
*FAIL*, handshake
EAP TRY #2
*FAIL*, handshake
EAP TRY #3
paperdesk
Post by paperdesk »
Here is a short video of the process:
https://photos.app.goo.gl/N2xEUuFBD2b7gWf52
Not sure what happened there.
When was this unit bought?
If you want to send it back to be checked out, send me a PM for a RMA number.
paperdesk
Post by paperdesk »
Could it possibly be the cable? Both adapters are several years old. Both units were working prior to this. Same code and same result. I really don't know what to make of it. I'll PM you, but unless we figure out what's going on I would expect the same thing to happen with a new unit.
