Problem with the Wifi module and a weird error
vonjankmon
Post by vonjankmon »
So my wifi module started acting odd, not connecting or connecting intermittently so I thought I would reset it and set it back up from scratch. Tried the WiFi setup tool but whenever I tried to send the configuration it would error out and tell me to reconnect the wifi module. Resetting it via the tool and via the little internal button did not resolve the issue at all.
So I moved onto the Terra Term option, it looks like it connected up fine but I can't get it to connect to my Wifi again. Also when I give the save command I don't get the "AOK" back, not sure if there is normal or whether the instructions are just a bit off. When I do a "get w" I get the following back:
<4.41> get w
SSID=FiOS-TCW4X
Chan=0
ExtAnt=0
Join=0
Auth=MIXED
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=30
Passphrase=**************
EAP_Id=userid
EAP_User=peap-user
Not sure why the EAP lines are there but they are not in the instructions.
I also periodically get *ERR WATCHDOG: 2EA00* showing up after a reboot in the Terra Term window.
Does anyone have any ideas on how I could fix this or did my WiFi module die?
Re: Problem with the Wifi module and a weird error
Can you post "get e"?
vonjankmon
Here is my get e:
get e
wifly-GSX Ver: 4.41 Build: r1057, Jan 17 2014 10:26:29 on RN-131
SSID=WiFly-GSX-b9
Pass=
Linkmon=3600
Beacon=102
Reboot=0
IF=DOWN
DHCP=ON
IP=0.0.0.0:2000
NM=255.255.255.0
GW=0.0.0.0
HOST=0.0.0.0:2000
PROTO=TCP,
MTU=1524
FLAGS=0x7
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1024
MatchChar=0
FlushTimer=5
IdleTimer=0
CmdChar=$
DNS=0.0.0.0
Name=dns1
Backup=rn.microchip.com
Lease=86400
FTP=0.0.0.0:21
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=FiOS-TCW4X
Chan=0
ExtAnt=0
Join=0
Auth=MIXED
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=30
Passphrase=***************
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x1
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x1
LaunchStr=web_app
TimeEna=0
TIMEADR=64.90.182.55:123
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x0
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
DeviceId=WiFly-GSX
Password=
Format=0x0
Signal=0
Average=5
BCAST=255.255.255.255:55555
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
The ssid and password are not set.
Can you post the sequence when you set them and send the save command?
vonjankmon
Alright did a hard reset and started from scratch, here is everything: (I replaced my passphrase with *********** but it is in there)
CMD
set s p 0
AOK
<4.41> set u b 57600
AOK
<4.41> save
Storing in config
<4.41> reboot
*Reboot*CMD
get w
SSID=roving1
Chan=0
ExtAnt=0
Join=0
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=30
Passphrase=rubygirl
EAP_Id=userid
EAP_User=peap-user
<4.41> set c o 0
AOK
<4.41> set c r 0
AOK
<4.41> set cc 0
ERR: 2few Args
<4.41> set c c 0
AOK
<4.41> set c s 1024
AOK
<4.41> set w a 4
AOK
<4.41> set w p ****************
AOK
<4.41> set w s FiOS-TCW4X
AOK
<4.41> get w
SSID=FiOS-TCW4X
Chan=0
ExtAnt=0
Join=0
Auth=MIXED
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=30
Passphrase=*****************
EAP_Id=userid
EAP_User=peap-user
<4.41> save
Storing in config
<4.41> reboot
*Reboot*CMD
get i
IF=DOWN
DHCP=ON
IP=0.0.0.0:2000
NM=255.255.255.0
GW=0.0.0.0
HOST=0.0.0.0:2000
PROTO=TCP,
MTU=1524
FLAGS=0x7
TCPMODE=0x0
BACKUP=0.0.0.0
<4.41> get e
SSID=WiFly-GSX-b9
Pass=
Linkmon=3600
Beacon=102
Reboot=0
IF=DOWN
DHCP=ON
IP=0.0.0.0:2000
NM=255.255.255.0
GW=0.0.0.0
HOST=0.0.0.0:2000
PROTO=TCP,
MTU=1524
FLAGS=0x7
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1024
MatchChar=0
FlushTimer=5
IdleTimer=0
CmdChar=$
DNS=0.0.0.0
Name=dns1
Lease=86400
FTP=0.0.0.0:21
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=FiOS-TCW4X
Chan=0
ExtAnt=0
Join=0
Auth=MIXED
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=30
Passphrase=********************
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x1
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x0
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
DeviceId=WiFly-GSX
Password=
Format=0x0
Signal=0
Average=5
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
vonjankmon
One thing I noticed was that the auth is set to mixed but I am trying to set it to WAP2, which in the instructions is value 4, which I used. Could that be a part of the problem? And if so what value should I use then?
Really thinking there is just something wrong with the hardware at this point since the setup wizard doesn't work and I am having to use TerraTerm but if anyone has any idea please let me know.
Are you sure you are using the macro posted on this thread?
Join is never set to 1, so the module will never connect to your wifi.
vonjankmon
Awesome! That worked, the script to correct the settings got everything up and running again.
